Aller au contenu principal
GameSir X2 Type-C Right Joystick Replacement
Ce dont vous avez besoin
  1. GameSir X2 Type-C Right Joystick Replacement, Back Cover: étape 1, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement, Back Cover: étape 1, image 2 de 2
    • Turn the device so the back faces you.
  2. GameSir X2 Type-C Right Joystick Replacement: étape 2, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 2, image 2 de 2
    • Remove the eight 6 mm T6 Torx screws.
  3. GameSir X2 Type-C Right Joystick Replacement: étape 3, image 1 de 1
    • Use a straight edge to remove the rubber pad on the front of the device.
  4. GameSir X2 Type-C Right Joystick Replacement: étape 4, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 4, image 2 de 2
    • Remove the four 4.5 mm screws with a Phillips #000 screwdriver.
  5. GameSir X2 Type-C Right Joystick Replacement: étape 5, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 5, image 2 de 2
    • Use a straight edge to pry open the controller, following the seam on the controller.
    • Some force is necessary, but be careful not to damage any of the clips holding the controller together.
  6. GameSir X2 Type-C Right Joystick Replacement, Right Joystick: étape 6, image 1 de 3 GameSir X2 Type-C Right Joystick Replacement, Right Joystick: étape 6, image 2 de 3 GameSir X2 Type-C Right Joystick Replacement, Right Joystick: étape 6, image 3 de 3
    • Remove six 4.5 mm screws using the Phillips #000 screwdriver.
  7. GameSir X2 Type-C Right Joystick Replacement: étape 7, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 7, image 2 de 2
    • Remove the left panel of the back cover to expose the joystick.
    • The joystick is attached to the black board.
  8. GameSir X2 Type-C Right Joystick Replacement: étape 8, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 8, image 2 de 2
    • Remove three 6 mm screws using a Phillips #00 screwdriver.
  9. GameSir X2 Type-C Right Joystick Replacement: étape 9, image 1 de 2 GameSir X2 Type-C Right Joystick Replacement: étape 9, image 2 de 2
    • Pull the joystick assembly out.
Malak Moustafa
Membre depuis le 02/14/24
248 Réputation
1 tutoriel rédigé
Équipe
University of Memphis, Team 1-2, Sneed Spring 2024 Membre de l'équipe University of Memphis, Team 1-2, Sneed Spring 2024
UM-SNEED-S24S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 47
Total : 109
