Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Garmin Vivoactive Wristband Replacement
Ce dont vous avez besoin
  1. Garmin Vivoactive Wristband Replacement, Wristband: étape 1, image 1 de 1
    • Hold the the metal screwdriver, with a T5 Torx bit, in your dominant hand.
    • Hold the rubber screwdriver, with a Hex T6 Torx bit, in your other hand.
    • While holding the rubber screwdriver in place, simultaneously unscrew the pin (counterclockwise) with the metal screwdriver in your dominant hand.
    Demander à FixBot
    Ajouter un commentaire
  2. Garmin Vivoactive Wristband Replacement: étape 2, image 1 de 2 Garmin Vivoactive Wristband Replacement: étape 2, image 2 de 2
    • Once the 1mm screw is removed, reinsert the metal screwdriver in that same hole.
    • Gently push the strap's pin out. It will begin to protrude from the other end.
    • Use your fingers to grab the exposed pin and slide it free. The strap should now be disconnected from the device.
    Demander à FixBot
Repeat steps to remove the second band end. To reassemble your device, follow these instructions in reverse order using new band ends.
4 autres ont terminé cette réparation.
Nathan LeTavec
Membre depuis le 10/01/15
679 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 1-21, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 1-21, Maness Fall 2015
CPSU-MANESS-F15S1G21
4 membres
17 tutoriels rédigés
1 commentaire de tutoriel
Most Garmin watches use the same style pin and the same instructions apply for changing the band. Be aware that the Vivoactive HR, the successor to the Vivoactive, uses only ONE size Torx screwdriver for both sides of the pin. You need 2 screwdrivers of the same size.
What size? Sorry but I don’t know. My Torx screwdrivers came with a replacement band kit and the instructions don’t say.
Google does a bad job of distinguishing results between the Vivoactive and the Vivoactive HR. Just wanted to make people aware so they aren’t confused.
Bruce Morris - Réponse Partager
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 19
30 derniers jours : 115
Total : 36,788
