Aller au contenu principal
Graco Paint Sprayers 17C325 2015 Gun Filter Replacement
Ce dont vous avez besoin
  1. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: étape 1, image 1 de 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: étape 1, image 2 de 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Handle: étape 1, image 3 de 3
    • Before you begin, make sure to follow the pressure relief procedure documented in the user manual before disconnecting and disassembling the spray gun.
    • Unscrew and remove the handle from the spray gun body.
    • You may need to use a pipe wrench to loosen the handle before removing it.
  2. Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: étape 2, image 1 de 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: étape 2, image 2 de 3 Graco Paint Sprayers 17C325 2015 Gun Filter Replacement, Remove the Filter: étape 2, image 3 de 3
    • Use your fingers to remove the blue-tipped filter from the inside of the handle.
4 autres ont terminé cette réparation.
Craig Lloyd
Membre depuis le 02/10/16
35 617 Réputation
82 tutoriels rédigés
3 commentaires
It would be beneficial to have the part numbers in this information as well! Otherwise, great job! Thanks
JANET - Réponse
part number for the gun filter??????
BRITTINEY - Réponse
288749 60 mesh gun filter
RICHARD -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 48
Total : 1,904
