Aller au contenu principal
HP 14-dq0051dx Touchpad Replacement
Ce dont vous avez besoin
  1. HP 14-dq0051dx Touchpad Replacement, Back Case: étape 1, image 1 de 2 HP 14-dq0051dx Touchpad Replacement, Back Case: étape 1, image 2 de 2
    • Turn the laptop upside down so the backside is facing up.
    • Use a Phillips #1 screwdriver to remove eight screws from the back case.
  2. HP 14-dq0051dx Touchpad Replacement: étape 2, image 1 de 1
    • Turn the laptop over and open the screen.
    • Insert the opening tool into the seam between the bottom panel and the keyboard.
    • Run the opening tool along the entire seam to separate the bottom panel.
    • You may hear clicking as you release the taps that secure the case.
  3. HP 14-dq0051dx Touchpad Replacement: étape 3, image 1 de 1
    • Once the bottom panel is separated from the laptop, carefully close the laptop and turn it upside down.
    • Place both your hands on opposite ends of the bottom panel, and lift up and remove the panel.
  4. HP 14-dq0051dx Touchpad Replacement, Battery: étape 4, image 1 de 3 HP 14-dq0051dx Touchpad Replacement, Battery: étape 4, image 2 de 3 HP 14-dq0051dx Touchpad Replacement, Battery: étape 4, image 3 de 3
    • Use a Phillips #1 screwdriver to remove the four 2.5 mm screws that secure the battery.
    • Remove the battery from the laptop.
  5. HP 14-dq0051dx Touchpad Replacement, Touchpad: étape 5, image 1 de 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: étape 5, image 2 de 3 HP 14-dq0051dx Touchpad Replacement, Touchpad: étape 5, image 3 de 3
    • Use the tip of a spudger or your fingernail to flip up the small locking flap from ZIF connector that attaches the touchpad cable to the motherboard.
    • Pull the ribbon cable out from the connector.
    • Use caution and do not yank or kink the cable, as you might damage it.
  6. HP 14-dq0051dx Touchpad Replacement: étape 6, image 1 de 3 HP 14-dq0051dx Touchpad Replacement: étape 6, image 2 de 3 HP 14-dq0051dx Touchpad Replacement: étape 6, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the three 2.0 mm screws from the metal plate covering the bottom of the touch pad.
    • Use an opening tool to remove the bottom plate.
  7. HP 14-dq0051dx Touchpad Replacement: étape 7, image 1 de 3 HP 14-dq0051dx Touchpad Replacement: étape 7, image 2 de 3 HP 14-dq0051dx Touchpad Replacement: étape 7, image 3 de 3
    • Lift up the flap covering to the top of the touchpad.
    • Use a Phillips #1 screwdriver to remove the three 1.5 mm screws from the top of the touchpad.
    • Use the opening tool to carefully lift up and remove the touchpad.
Lily Mahaffee
Membre depuis le 01/18/23
430 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 19
Total : 190
