Introduction
This leads the reader through removing the hard drive for replacement. The hard drive may need replacing if it is too slow or makes odd noises while running. If you are not encountering these specific issues with your computer, check the HP 15-ay052nr troubleshooting page to direct yourself towards the guide most beneficial towards your issue.
Ce dont vous avez besoin
Turn the device and lay it upside-down on a flat surface so the base of the computer is facing upwards.
Remove the rubber feet on the bottom of the device to access all the screws.
Remove the three 3 mm screws that mount the hard drive to the computer.
