Aller au contenu principal
HP 15-bs051od Screen Replacement
Ce dont vous avez besoin
  1. HP 15-bs051od Screen Replacement, RAM: étape 1, image 1 de 1
    • Start with the laptop face down.
    • Remove the eight 6 mm Phillips head screws securing the lower case.
  2. HP 15-bs051od Screen Replacement: étape 2, image 1 de 2 HP 15-bs051od Screen Replacement: étape 2, image 2 de 2
    • Use the opening tool to pry the lower case away from the body of the laptop.
    • Remove the lower case.
  3. HP 15-bs051od Screen Replacement: étape 3, image 1 de 3 HP 15-bs051od Screen Replacement: étape 3, image 2 de 3 HP 15-bs051od Screen Replacement: étape 3, image 3 de 3
    • Pull the RAM-retaining arms away from the RAM chip.
    • The RAM chip should slightly "pop" up from it's socket.
  4. HP 15-bs051od Screen Replacement: étape 4, image 1 de 2 HP 15-bs051od Screen Replacement: étape 4, image 2 de 2
    • Pull the RAM chip out of its socket.
    • Our device does not specifically have a second RAM chip, but make sure to remove the second RAM chip below the first RAM chip.
    • Repeat this process for the second RAM chip.
  5. HP 15-bs051od Screen Replacement, Motherboard: étape 5, image 1 de 3 HP 15-bs051od Screen Replacement, Motherboard: étape 5, image 2 de 3 HP 15-bs051od Screen Replacement, Motherboard: étape 5, image 3 de 3
    • Remove the four (4 mm) Phillips screws on the heatsink.
    • Remove the exhaust by carefully lifting it up.
  6. HP 15-bs051od Screen Replacement: étape 6, image 1 de 1
    • Disconnect the connecting cable of the fan and remove the fan.
  7. HP 15-bs051od Screen Replacement: étape 7, image 1 de 2 HP 15-bs051od Screen Replacement: étape 7, image 2 de 2
    • Pull the red, white, black, and blue cable directly out of its port.
  8. HP 15-bs051od Screen Replacement: étape 8, image 1 de 1
    • Slide the left speaker out.
  9. HP 15-bs051od Screen Replacement: étape 9, image 1 de 1
    • Pull the black and red cable connecting both speakers out of its secure fastening.
  10. HP 15-bs051od Screen Replacement: étape 10, image 1 de 1
    • Pull the right speaker out by sliding from left to right.
  11. HP 15-bs051od Screen Replacement: étape 11, image 1 de 2 HP 15-bs051od Screen Replacement: étape 11, image 2 de 2
    • Locate the motherboard.
    • The motherboard is the biggest blue-colored surface located inside the computer.
    • Locate the six ribbon cables.
  12. HP 15-bs051od Screen Replacement: étape 12, image 1 de 2 HP 15-bs051od Screen Replacement: étape 12, image 2 de 2
    • Flip up the ZIF lock bars that keep the six ribbon cables in place.
    • Slide the rest of the ribbon cables out of their fastenings.
  13. HP 15-bs051od Screen Replacement: étape 13, image 1 de 2 HP 15-bs051od Screen Replacement: étape 13, image 2 de 2
    • Remove the four (4 mm) Phillips screws securing the motherboard.
  14. HP 15-bs051od Screen Replacement: étape 14, image 1 de 2 HP 15-bs051od Screen Replacement: étape 14, image 2 de 2
    • Remove the single (4 mm) Phillips screw on the Wi-Fi card.
    • Slide the Wi-Fi card out of its port.
  15. HP 15-bs051od Screen Replacement: étape 15, image 1 de 2 HP 15-bs051od Screen Replacement: étape 15, image 2 de 2
    • Unfasten the connecting cable.
  16. HP 15-bs051od Screen Replacement: étape 16, image 1 de 2 HP 15-bs051od Screen Replacement: étape 16, image 2 de 2
    • Remove the display cable.
  17. HP 15-bs051od Screen Replacement: étape 17, image 1 de 1
    • Lift up the motherboard.
  18. HP 15-bs051od Screen Replacement, Screen: étape 18, image 1 de 1
    • Remove the following Phillips screws:
    • Five 7 mm screws on the display hinge.
    • One 3 mm screw.
  19. HP 15-bs051od Screen Replacement: étape 19, image 1 de 1
    • Partially open the laptop and remove the base.
  20. HP 15-bs051od Screen Replacement: étape 20, image 1 de 2 HP 15-bs051od Screen Replacement: étape 20, image 2 de 2
    • Use the opening tool to carefully separate the screen cover from the screen.
    • Use the opening tool to carefully remove the adhesive screen bezel from around the screen.
  21. HP 15-bs051od Screen Replacement: étape 21, image 1 de 1
    • Two 4 mm screws from the top of the screen.
    • Two 4 mm from the bottom of the screen.
  22. HP 15-bs051od Screen Replacement: étape 22, image 1 de 1
    • Carefully lift the screen from the display assembly without disconnecting the display cable.
  23. HP 15-bs051od Screen Replacement: étape 23, image 1 de 1
    • Remove the display cable from the back of the screen.
  24. HP 15-bs051od Screen Replacement: étape 24, image 1 de 1
    • Remove the screen from the display assembly.
Kaz Furtado
Membre depuis le 03/20/23
148 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 6-1, Botvin Spring 2023 Membre de l'équipe UMass Dartmouth, Team 6-1, Botvin Spring 2023
UMASSD-BOTVIN-S23S6G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 162
