Aller au contenu principal
HP 15-ef2025nr Trackpad Replacement
Ce dont vous avez besoin
  1. HP 15-ef2025nr Trackpad Replacement, Battery: étape 1, image 1 de 1
    • Turn the laptop upside down with the hinge facing you.
  2. HP 15-ef2025nr Trackpad Replacement: étape 2, image 1 de 2 HP 15-ef2025nr Trackpad Replacement: étape 2, image 2 de 2
    • Use an opening tool to remove the rubber strips by prying up a corner and gently pulling off the strip.
  3. HP 15-ef2025nr Trackpad Replacement: étape 3, image 1 de 2 HP 15-ef2025nr Trackpad Replacement: étape 3, image 2 de 2
    • Use a Phillips screwdriver to remove the eight 3 mm screws (including the 2 screws that were not under the rubber strips) securing the lower case.
  4. HP 15-ef2025nr Trackpad Replacement: étape 4, image 1 de 2 HP 15-ef2025nr Trackpad Replacement: étape 4, image 2 de 2
    • Flip the laptop over and open the lid.
    • Insert an opening tool into the seam between the edge of the lower case and the chassis.
    • Gently pry around the entire perimeter until the lower case separates from the chassis.
    • Close the lid and flip the laptop back over.
    • Remove the lower case.
  5. HP 15-ef2025nr Trackpad Replacement: étape 5, image 1 de 3 HP 15-ef2025nr Trackpad Replacement: étape 5, image 2 de 3 HP 15-ef2025nr Trackpad Replacement: étape 5, image 3 de 3
    • Remove the five 2 mm Phillips screws holding the battery down.
    • Take care not to puncture, bend, or twist the battery. Lithium batteries can be very volatile. Follow all proper hazardous disposal laws where you live.
    • Gently lift the front edge of the battery up to disconnect the socket.
    • Lift the battery up and out.
  6. HP 15-ef2025nr Trackpad Replacement, Trackpad: étape 6, image 1 de 2 HP 15-ef2025nr Trackpad Replacement, Trackpad: étape 6, image 2 de 2
    Outil utilisé dans cette étape :
    J'achète
    • Use tweezers to flip up the ZIF connector locking flap.
    • Use tweezers to disconnect the ribbon cable from the back of the track pad.
  7. HP 15-ef2025nr Trackpad Replacement: étape 7, image 1 de 3 HP 15-ef2025nr Trackpad Replacement: étape 7, image 2 de 3 HP 15-ef2025nr Trackpad Replacement: étape 7, image 3 de 3
    • Remove the six 2 mm Phillips screws securing the trackpad.
    • Remove the retaining plate from the bottom of the track pad.
    • Remove the track pad.
Maribella Rivera
Membre depuis le 02/13/23
327 Réputation
3 tutoriels rédigés
Équipe
Austin Community College, Team 1-1, Watkins Spring 2023 Membre de l'équipe Austin Community College, Team 1-1, Watkins Spring 2023
AUSTINCC-WATKINS-S23S1G1
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 6
Total : 171
