Introduction
This guide will enable you to remove and replace the cameras on your HP 7 Plus. This involves taking the rear cover off the tablet and opening it up to disconnect and remove the cameras. It's pretty straightforward but this guide will escort you through the process even if you've never worked with electronics before. You will, however, need to have access to the tools listed below.
*In order to access the camera, please refer to the HP 7 Plus 1302 Back Cover Removal Guide
Relevant Parts
Ce dont vous avez besoin
Using the T5 Torx Screwdriver, remove the T5x3mm screws located in all 4 corners.
Locate the small grey connector near the top of the device. Using the Spudger tool, gently pull it away from the device until it releases its connection.
