Aller au contenu principal
HP Chromebook 11-v019wm Keyboard Replacement
Ce dont vous avez besoin
  1. HP Chromebook 11-v019wm Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Disconnect the power adapter from the charging port and remove all external media devices from the Chromebook.
    • Turn the Chromebook over so the bottom of the computer is facing upwards with the hinge facing away.
  2. HP Chromebook 11-v019wm Keyboard Replacement: étape 2, image 1 de 2 HP Chromebook 11-v019wm Keyboard Replacement: étape 2, image 2 de 2
    • Remove the (4) rubber feet with the plastic spudger to reveal the screws underneath.
    • The rubber feet are secured with adhesive and may take time to remove.
  3. HP Chromebook 11-v019wm Keyboard Replacement: étape 3, image 1 de 2 HP Chromebook 11-v019wm Keyboard Replacement: étape 3, image 2 de 2
    • Remove the (2), oval shaped, rubber screw protectors near the hinge of the Chromebook.
    • The rubber screw protectors are secured with adhesive and may take time to remove.
  4. HP Chromebook 11-v019wm Keyboard Replacement: étape 4, image 1 de 2 HP Chromebook 11-v019wm Keyboard Replacement: étape 4, image 2 de 2
    • Remove the (11) 5.2 mm screws using a Phillips #00 Screwdriver.
  5. HP Chromebook 11-v019wm Keyboard Replacement: étape 5, image 1 de 2 HP Chromebook 11-v019wm Keyboard Replacement: étape 5, image 2 de 2
    • Place the Chromebook upright and open the screen all the way.
    • Starting towards the hinge, insert the spudger between the silver keyboard decking and the charcoal colored casing.
    • Pry upwards to release the tabs that are securing the keyboard to the casing.
    • Repeat this process around the perimeter of the keyboard to ensure all tabs are released.
    • Once all the tabs are released, gently lift the keyboard to gain access to the (2) Zero Insertion Force (ZIF) ribbon cables.
  6. HP Chromebook 11-v019wm Keyboard Replacement: étape 6, image 1 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 6, image 2 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 6, image 3 de 3
    Outil utilisé dans cette étape :
    Anti-Static Wrist Strap
    $7.95
    J'achète
    • Using the hook on the Halberd Spudger, lift up the ZIF connector tab for the keyboard ribbon cable. They keyboard ribbon cable is the larger of the two ribbon cables.
    • The remaining steps should be completed with the anti-static wrist strap to prevent damage to electrostatic discharge (ESD) sensitive components.
  7. HP Chromebook 11-v019wm Keyboard Replacement: étape 7, image 1 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 7, image 2 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 7, image 3 de 3
    • With the ZIF connector tab in the upright position, use your fingers to gently pull the keyboard ribbon cable out of the ZIF connector.
  8. HP Chromebook 11-v019wm Keyboard Replacement: étape 8, image 1 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 8, image 2 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 8, image 3 de 3
    • With the hook on the Halberd Spudger, lift the ZIF connector that is holding the Touchpad ribbon cable. The Touchpad ribbon cable is the smaller of the two ribbon cables.
  9. HP Chromebook 11-v019wm Keyboard Replacement: étape 9, image 1 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 9, image 2 de 3 HP Chromebook 11-v019wm Keyboard Replacement: étape 9, image 3 de 3
    • With the ZIF connector tab in the upright position, use your fingers to gently pull the Touchpad ribbon cable out of the ZIF connector.
  10. HP Chromebook 11-v019wm Keyboard Replacement: étape 10, image 1 de 1
    • With both ribbon cables disconnected, the keyboard can now be safely removed from the Chromebook.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 7
30 derniers jours : 12
Total : 366
