Introduction
The microphone/webcam cable connects the webcam module above the LCD display to the motherboard.
If the cable connection is loose or the cable no longer is working then you will not be able to use your webcam or microphone.
Check the resources listed in the troubleshooting page to see if you can correct the issue without replacement. If you are still having issues, see below for a replacement guide to assist.
Ce dont vous avez besoin
Remove six 6.6 mm screws from the back case using a Phillips #1 screwdriver.
Remove two 8.7 mm screws from the back case using a Phillips #1 screwdriver.
Turn the computer over and open it as if you are going to use it.
