Aller au contenu principal
HP Chromebook 14 G4 Touchpad Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14 G4 Touchpad Replacement, Keyboard Assembly: étape 1, image 1 de 2 HP Chromebook 14 G4 Touchpad Replacement, Keyboard Assembly: étape 1, image 2 de 2
    • Remove the thirteen 2.5 mm Phillips #0 screws on the underside of the laptop that secure the keyboard assembly.
    • Flip the laptop over and open the lid.
    • Insert a nylon spudger in the gap between the keyboard assembly and lower case.
    • Gently pry around the entire perimeter until the keyboard assembly fully releases.
  2. HP Chromebook 14 G4 Touchpad Replacement: étape 2, image 1 de 3 HP Chromebook 14 G4 Touchpad Replacement: étape 2, image 2 de 3 HP Chromebook 14 G4 Touchpad Replacement: étape 2, image 3 de 3
    • Slightly lift the keyboard assembly with care not to strain the attached ribbon cables.
    • Flip up the two black ZIF locking flaps that secure the keyboard and touchpad ribbon cables to their motherboard sockets.
    • Gently pull the keyboard and touchpad ribbon cables out of their motherboard sockets.
  3. HP Chromebook 14 G4 Touchpad Replacement: étape 3, image 1 de 1
    • Lift the keyboard assembly off of the chassis.
  4. HP Chromebook 14 G4 Touchpad Replacement, Touchpad: étape 4, image 1 de 3 HP Chromebook 14 G4 Touchpad Replacement, Touchpad: étape 4, image 2 de 3 HP Chromebook 14 G4 Touchpad Replacement, Touchpad: étape 4, image 3 de 3
    • Lay the keyboard face down.
    • Use tweezers to lift the tape on the bottom of the touchpad to expose the connector.
    • Flip up the black ZIF locking flap that secures the touchpad ribbon cable.
    • Disconnect the touchpad ribbon cable.
  5. HP Chromebook 14 G4 Touchpad Replacement: étape 5, image 1 de 3 HP Chromebook 14 G4 Touchpad Replacement: étape 5, image 2 de 3 HP Chromebook 14 G4 Touchpad Replacement: étape 5, image 3 de 3
    • Use a Phillips #00 screwdriver to remove the two 2 mm screws that secure the touchpad to the black plastic housing.
    • Flip the keyboard mount to the upright position.
    • From beneath, push the touchpad up through the top of the keyboard mount to remove it.
Christian Leaman
Membre depuis le 09/05/24
551 Réputation
3 tutoriels rédigés
Équipe
Gateway, Team 8-3, Gonzalez Fall 2024 Membre de l'équipe Gateway, Team 8-3, Gonzalez Fall 2024
GCC-GONZALEZ-F24S8G3
5 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 36
