Aller au contenu principal
HP Chromebook 14-q029wm Battery Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-q029wm Battery Replacement, Keyboard: étape 1, image 1 de 1
    • Remove nine 5mm Phillips #0 screws from the back case.
    • Remove the rubber caps using a spudger.
    • Remove the four remaining 5mm Phillips #0 screws.
  2. HP Chromebook 14-q029wm Battery Replacement: étape 2, image 1 de 1
    • Use an opening tool to unclip the bottom plastic covering of the laptop.
    • Go around the sides of the laptop until the bottom unclips completely and comes off of the laptop.
    • Be careful not to break the plastic clips.
  3. HP Chromebook 14-q029wm Battery Replacement: étape 3, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
    • There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
    • Remove the larger wire first.
    • Then remove the smaller wire.
    • It is better to use a pair of tweezers for accuracy
    • From there the keyboard should completely come off.
  4. HP Chromebook 14-q029wm Battery Replacement, Battery: étape 4, image 1 de 1
    • Use your fingers to pull the white tab out of the black slot above the battery.
  5. HP Chromebook 14-q029wm Battery Replacement: étape 5, image 1 de 1
    • Remove the 3mm Phillips #0 screws.
  6. HP Chromebook 14-q029wm Battery Replacement: étape 6, image 1 de 1
    • Pick up and gently remove the battery.
Andrew Pratt
Membre depuis le 11/05/19
669 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G5, Barthe Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G5, Barthe Fall 2019
UMASSD-BARTHE-F19S1G5
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 334
