Introduction
If your HP Chromebook 14-q029wm has been having overheating problems recently try placing it in a space with better airflow or using compressed air and cleaning it out. If both of these don’t work your computer may have a faulty fan. After you determine if it is a faulty fan follow this guide below to remove and replace it. For more troubleshooting advice click here. This guide will walk you through how to take apart your HP Chromebook 14-q029wm safely and install a new fan. Make sure the power is completely off and no external power is plugged in.
Ce dont vous avez besoin
Remove nine 5mm Phillips #0 screws from the back case.
Remove the rubber caps using a spudger.
Remove the four remaining 5mm Phillips #0 screws.
Once the bottom is completely unclipped, remove the covering slowly so you do not pull and rip the wires.
There is a little black lever that you have to pull in order to remove the wires. They are found on top of where the wires are connected.
Remove the larger wire first.
Then remove the smaller wire.
From there the keyboard should completely come off.
Use your fingers to pull the white tab out of the black slot above the battery.
2 autres ont terminé cette réparation.
