Aller au contenu principal
HP Chromebook 14-q063cl Touchpad Replacement
Ce dont vous avez besoin
  1. HP Chromebook 14-q063cl Touchpad Replacement, Keyboard: étape 1, image 1 de 3 HP Chromebook 14-q063cl Touchpad Replacement, Keyboard: étape 1, image 2 de 3 HP Chromebook 14-q063cl Touchpad Replacement, Keyboard: étape 1, image 3 de 3
    • Flip the laptop upside down so that the bottom is facing upwards.
    • Use Phillips #0 screwdriver to remove nine 6.7 mm screws from the bottom panel.
  2. HP Chromebook 14-q063cl Touchpad Replacement: étape 2, image 1 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 2, image 2 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 2, image 3 de 3
    • Use a metal spudger to pry the plastic covers off four additional screws.
  3. HP Chromebook 14-q063cl Touchpad Replacement: étape 3, image 1 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 3, image 2 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the four remaining 6.7 mm screws from the bottom panel.
  4. HP Chromebook 14-q063cl Touchpad Replacement: étape 4, image 1 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 4, image 2 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 4, image 3 de 3
    • Turn the laptop upright.
    • Use an opening tool or picks to undo the clips around the perimeter of the keyboard assembly and separate it from the rest of the laptop.
    • Remove the keyboard assembly.
    • Disconnect the cable attaching the keyboard cable to the motherboard.
    • Use caution when removing the keyboard assembly so as to not break it or rip any cables or connectors attached to the board. Don't yank the keyboard assembly from the device.
  5. HP Chromebook 14-q063cl Touchpad Replacement, Touchpad: étape 5, image 1 de 2 HP Chromebook 14-q063cl Touchpad Replacement, Touchpad: étape 5, image 2 de 2
    Outil utilisé dans cette étape :
    $3.99
    J'achète
    • To safely remove the ribbon cable securing the touchpad ribbon cable is a ZIF connector, use the angled tweezers to lift up the plastic flap of the ZIF connector.
    • Use the angled tweezers to pull the touchpad ribbon cable from the connector on the motherboard.
  6. HP Chromebook 14-q063cl Touchpad Replacement: étape 6, image 1 de 1
    • Using the iFixit 64 screw driver with a Phillips #1 attachment, remove two 2 mm screws from the touchpad.
  7. HP Chromebook 14-q063cl Touchpad Replacement: étape 7, image 1 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 7, image 2 de 3 HP Chromebook 14-q063cl Touchpad Replacement: étape 7, image 3 de 3
    • Turn the keyboard so that it faces upwards.
    • Use your fingers to gently remove the touchpad from the keyboard.
Hannah Halliburton
Membre depuis le 02/21/23
755 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 58
