Aller au contenu principal
HP Chromebook CB2L Speaker Replacement
Ce dont vous avez besoin
  1. HP Chromebook CB2L Speaker Replacement, Battery: étape 1, image 1 de 2 HP Chromebook CB2L Speaker Replacement, Battery: étape 1, image 2 de 2
    • First flip your HP Chromebook CB2L over such that the bottom is facing upwards.
    • Next, using the plastic opening tool remove the blue panel.
  2. HP Chromebook CB2L Speaker Replacement: étape 2, image 1 de 3 HP Chromebook CB2L Speaker Replacement: étape 2, image 2 de 3 HP Chromebook CB2L Speaker Replacement: étape 2, image 3 de 3
    • Using the Phillips #1 screwdriver, remove the six 1.2mm screws.
    • Gently pry off the white back panel using the plastic opening tool.
  3. HP Chromebook CB2L Speaker Replacement: étape 3, image 1 de 1
    • Disconnect the battery input to the motherboard using the plastic opening tool
  4. HP Chromebook CB2L Speaker Replacement: étape 4, image 1 de 1
    • Unscrew the four 1.2mm screws using the Phillips #1 screwdriver.
  5. HP Chromebook CB2L Speaker Replacement: étape 5, image 1 de 1
    • Using the plastic opening tool remove the battery from the Chromebook.
  6. HP Chromebook CB2L Speaker Replacement, Speaker: étape 6, image 1 de 1
    • Using the plastic opening tool lift the black tab.
    • Disconnect the blue and black strip from the motherboard.
  7. HP Chromebook CB2L Speaker Replacement: étape 7, image 1 de 1
    • Use the Phillips #1 screwdriver to remove the four 1.2mm screws circled red.
  8. HP Chromebook CB2L Speaker Replacement: étape 8, image 1 de 3 HP Chromebook CB2L Speaker Replacement: étape 8, image 2 de 3 HP Chromebook CB2L Speaker Replacement: étape 8, image 3 de 3
    • Gently pull the black wire to disconnect the audio port from the motherboard.
    • Disconnect the black wire connecting the speaker to the motherboard with caution.
  9. HP Chromebook CB2L Speaker Replacement: étape 9, image 1 de 1
    • Use the plastic opening tool to remove the speaker from back panel.
Gregory Hinkson
Membre depuis le 02/13/17
352 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team S2-G6, Lacy Spring 2017 Membre de l'équipe USF Tampa, Team S2-G6, Lacy Spring 2017
USFT-LACY-S17S2G6
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 5
Total : 157
