Aller au contenu principal
HP Chromebook x360 11-ae010nr Speakers Replacement
Ce dont vous avez besoin
  1. HP Chromebook x360 11-ae010nr Speakers Replacement, Keyboard: étape 1, image 1 de 2 HP Chromebook x360 11-ae010nr Speakers Replacement, Keyboard: étape 1, image 2 de 2
    • Flip the device upside down so that the screws are visible.
    • Loosen two captive Phillips #1 screws from the center of the device.
    • Remove three 9.3 mm Phillips #1 screws from the joint side of the device.
    • Remove four 6.1 mm Phillips #1 screws from the opening side of the device.
  2. HP Chromebook x360 11-ae010nr Speakers Replacement: étape 2, image 1 de 3 HP Chromebook x360 11-ae010nr Speakers Replacement: étape 2, image 2 de 3 HP Chromebook x360 11-ae010nr Speakers Replacement: étape 2, image 3 de 3
    • Insert an iFixit opening tool between the edge of the keyboard assembly and the base of the device.
    • Push down on the handle of the opening tool to create an opening between the keyboard assembly and the base of the device.
    • Move the opening tool around the device, popping open the clips with force when necessary, until the keyboard assembly is fully lifted from the base of the device.
  3. HP Chromebook x360 11-ae010nr Speakers Replacement: étape 3, image 1 de 2 HP Chromebook x360 11-ae010nr Speakers Replacement: étape 3, image 2 de 2
    • Separate the keyboard assembly and the case.
    • Two cables connect the keyboard to the device, so take caution to not damage these cables.
    • Flip the black plastic tab where the wider cable meets the main board using the tip of a spudger or a fingernail.
    • Remove the cable with curved needle nose pliers or your fingers.
  4. HP Chromebook x360 11-ae010nr Speakers Replacement: étape 4, image 1 de 2 HP Chromebook x360 11-ae010nr Speakers Replacement: étape 4, image 2 de 2
    • Flip the white plastic tab where the thinner cable meets the main board using the tip of a spudger or a fingernail.
    • Separate the keyboard from the laptop.
  5. HP Chromebook x360 11-ae010nr Speakers Replacement, Speakers: étape 5, image 1 de 2 HP Chromebook x360 11-ae010nr Speakers Replacement, Speakers: étape 5, image 2 de 2
    • Remove the four 5 mm Phillips #1 screws from the left and right speakers.
  6. HP Chromebook x360 11-ae010nr Speakers Replacement: étape 6, image 1 de 2 HP Chromebook x360 11-ae010nr Speakers Replacement: étape 6, image 2 de 2
    • Remove the cable from the right speaker by removing the tape then detaching the cable.
  7. HP Chromebook x360 11-ae010nr Speakers Replacement: étape 7, image 1 de 1
    • Pull the white cable down to detach from the battery.
    • Remove the speakers from the laptop.
Devin Cannistraro
Membre depuis le 10/28/19
193 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G9, O'Connell Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G9, O'Connell Fall 2019
UMASSD-O'CONNELL-F19S1G9
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 6
30 derniers jours : 8
Total : 192
