Introduction
You should use this guide if the battery in your HP EliteBook 1050 G1 is defective. This usually occurs after you’ve had the laptop for an extended period of time and it no longer holds a charge for very long. This guide will help you bring your device back to life and extend its charge drastically.
For this guide, you will need a Phillips head screwdriver, an iFixit opening tool, and a spudger. This guide is also a helpful prerequisite if you need to replace other components inside the body of your device.
If your battery is swollen, take appropriate precautions.
Ce dont vous avez besoin
Close your laptop and turn it over so that the side without the HP logo is facing you.
Using the TR9 screwdriver, loosen the nine screws from the base of the device.
