Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HP EliteBook 850 G3 Fan Replacement
Ce dont vous avez besoin
  1. HP EliteBook 850 G3 Fan Replacement, Battery: étape 1, image 1 de 1
    • Turn off your laptop before starting.
    • Flip the laptop over so the model stickers face up.
  2. HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: étape 2, image 1 de 2 HP EliteBook 850 G3 Fan Replacement, Unscrew the bottom: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Fan Replacement: étape 3, image 1 de 2 HP EliteBook 850 G3 Fan Replacement: étape 3, image 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry the back off.
  4. HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: étape 4, image 1 de 2 HP EliteBook 850 G3 Fan Replacement, Remove the battery screws: étape 4, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the two battery screws.
    • The two battery screws are captured screws and do not come out.
  5. HP EliteBook 850 G3 Fan Replacement, Lift the battery: étape 5, image 1 de 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: étape 5, image 2 de 3 HP EliteBook 850 G3 Fan Replacement, Lift the battery: étape 5, image 3 de 3
    • Lift and pull the flap located at the top of the battery to remove it.
  6. HP EliteBook 850 G3 Fan Replacement, Fan: étape 6, image 1 de 1
    • Gently unclip the plastic frame.
  7. HP EliteBook 850 G3 Fan Replacement: étape 7, image 1 de 3 HP EliteBook 850 G3 Fan Replacement: étape 7, image 2 de 3 HP EliteBook 850 G3 Fan Replacement: étape 7, image 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  8. HP EliteBook 850 G3 Fan Replacement: étape 8, image 1 de 2 HP EliteBook 850 G3 Fan Replacement: étape 8, image 2 de 2
    • Carefully remove the connector for the fan.
  9. HP EliteBook 850 G3 Fan Replacement: étape 9, image 1 de 3 HP EliteBook 850 G3 Fan Replacement: étape 9, image 2 de 3 HP EliteBook 850 G3 Fan Replacement: étape 9, image 3 de 3
    • Carefully remove the fan and heatsink assembly from the laptop.
2 autres ont terminé cette réparation.
Annabeth Grover
Membre depuis le 10/10/19
1 030 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 membres
12 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 39
Total : 3,286
