Aller au contenu principal
HP EliteBook 850 G3 Motherboard Replacement
Ce dont vous avez besoin
  1. HP EliteBook 850 G3 Motherboard Replacement, WiFi Card: étape 1, image 1 de 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 Motherboard Replacement: étape 2, image 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 Motherboard Replacement: étape 3, image 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: étape 3, image 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 Motherboard Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 Motherboard Replacement: étape 5, image 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: étape 5, image 2 de 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 Motherboard Replacement: étape 6, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 6, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 6, image 3 de 3
    • Disconnect the coaxial cables wires from the WiFi card.
  7. HP EliteBook 850 G3 Motherboard Replacement, Fan: étape 7, image 1 de 1
    • Gently unclip the plastic frame.
  8. HP EliteBook 850 G3 Motherboard Replacement: étape 8, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 8, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 8, image 3 de 3
    • Use a Phillips #0 screwdriver to unscrew the four captive screws located near the fan and heatsink assembly.
  9. HP EliteBook 850 G3 Motherboard Replacement: étape 9, image 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: étape 9, image 2 de 2
    • Carefully remove the connector for the fan.
  10. HP EliteBook 850 G3 Motherboard Replacement: étape 10, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 10, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 10, image 3 de 3
    • Carefully remove the fan and heatsink assembly from the laptop.
    • Slide out RAM (not pictured).
  11. HP EliteBook 850 G3 Motherboard Replacement: étape 12, image 1 de 1
    • Use a #00 Phillips screwdriver to remove twelve 5.7 mm screws from the motherboard.
  12. HP EliteBook 850 G3 Motherboard Replacement: étape 13, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 13, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 13, image 3 de 3
    • Remove the wire connectors.
  13. HP EliteBook 850 G3 Motherboard Replacement: étape 14, image 1 de 2 HP EliteBook 850 G3 Motherboard Replacement: étape 14, image 2 de 2
    • Jiggle the motherboard until the ports (ie. headphone jack) come out from the sides and you can lift it up.
  14. HP EliteBook 850 G3 Motherboard Replacement: étape 15, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 15, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 15, image 3 de 3
    • Disconnect the wires underneath.
  15. HP EliteBook 850 G3 Motherboard Replacement: étape 16, image 1 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 16, image 2 de 3 HP EliteBook 850 G3 Motherboard Replacement: étape 16, image 3 de 3
    • Take out the motherboard.
Annabeth Grover
Membre depuis le 10/10/19
922 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 60
Total : 3,346
