Aller au contenu principal
HP EliteBook 850 G3 WiFi Card Replacement
Ce dont vous avez besoin
  1. HP EliteBook 850 G3 WiFi Card Replacement, WiFi Card: étape 1, image 1 de 1
    • Turn off your laptop before starting
    • Flip the laptop over so the model stickers face the ceiling.
  2. HP EliteBook 850 G3 WiFi Card Replacement: étape 2, image 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: étape 2, image 2 de 2
    • Use a Phillips #0 screwdriver to remove eleven 5.7mm screws.
  3. HP EliteBook 850 G3 WiFi Card Replacement: étape 3, image 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: étape 3, image 2 de 2
    • Insert the iFixit opening pick underneath the plastic back of the laptop. Use force to pry back off.
  4. HP EliteBook 850 G3 WiFi Card Replacement: étape 4, image 1 de 1
    • Use the Phillips #0 screwdriver to remove the 3.3mm screw on the WiFi card.
  5. HP EliteBook 850 G3 WiFi Card Replacement: étape 5, image 1 de 2 HP EliteBook 850 G3 WiFi Card Replacement: étape 5, image 2 de 2
    • Slide out the WiFi card.
  6. HP EliteBook 850 G3 WiFi Card Replacement: étape 6, image 1 de 3 HP EliteBook 850 G3 WiFi Card Replacement: étape 6, image 2 de 3 HP EliteBook 850 G3 WiFi Card Replacement: étape 6, image 3 de 3
    • Disconnect the coaxial cables wires from the WiFi card.
2 autres ont terminé cette réparation.
Annabeth Grover
Membre depuis le 10/10/19
922 Réputation
5 tutoriels rédigés
Équipe
USF Tampa, Team S1-G1, Leahy Fall 2019 Membre de l'équipe USF Tampa, Team S1-G1, Leahy Fall 2019
USFT-LEAHY-F19S1G1
4 membres
6 tutoriels rédigés
Un commentaire
Thank you, my HP Elitebook 850 G3 had a faulty WiFi module, it would only turn on for a second and turn off all the time in Windows 10. Tried everything inc latest drivers and clean W10 install. This guide made it easier than I thought. Replaced WiFi module with a new ordered spare and it works perfectly now.
MV9000 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 29
Total : 1,547
