Aller au contenu principal
HP EliteBook 8560w Hard Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook 8560w Hard Drive Replacement, Battery: étape 1, image 1 de 2 HP EliteBook 8560w Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Hard Drive Replacement: étape 2, image 1 de 1
    • Pull the battery out.
  3. HP EliteBook 8560w Hard Drive Replacement, Back Panel: étape 3, image 1 de 2 HP EliteBook 8560w Hard Drive Replacement, Back Panel: étape 3, image 2 de 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Hard Drive Replacement: étape 4, image 1 de 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Hard Drive Replacement, Hard Drive: étape 5, image 1 de 2 HP EliteBook 8560w Hard Drive Replacement, Hard Drive: étape 5, image 2 de 2
    • Make sure your device is powered off and its battery removed.
    • Remove the four M2.5x8mm screws with Phillips #0 screwdriver and lift up the panel to access your Hard Drive.
  6. HP EliteBook 8560w Hard Drive Replacement: étape 6, image 1 de 3 HP EliteBook 8560w Hard Drive Replacement: étape 6, image 2 de 3 HP EliteBook 8560w Hard Drive Replacement: étape 6, image 3 de 3
    • Remove the M2.5x8mm screw with Phillips #0 screwdriver.
    • Slide the hard drive to the left and lift it to remove it.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 30
Total : 1,661
