Aller au contenu principal
HP EliteBook 8560w Keyboard Replacement
Ce dont vous avez besoin
  1. HP EliteBook 8560w Keyboard Replacement, Battery: étape 1, image 1 de 2 HP EliteBook 8560w Keyboard Replacement, Battery: étape 1, image 2 de 2
    • Make sure your device is powered off and disconnected from the power adapter.
    • Slide the lock all the way to the left. The battery should pop up.
  2. HP EliteBook 8560w Keyboard Replacement: étape 2, image 1 de 1
    • Pull the battery out.
  3. HP EliteBook 8560w Keyboard Replacement, Back Panel: étape 3, image 1 de 2 HP EliteBook 8560w Keyboard Replacement, Back Panel: étape 3, image 2 de 2
    • Slide the lock all the way to the right and remove the M2.5x8mm screw with a Philips #0 screwdriver.
    • Make sure your device is turned off and your battery is removed.
  4. HP EliteBook 8560w Keyboard Replacement: étape 4, image 1 de 1
    • Slide the panel towards you and lift it up to open and access the back of the computer.
  5. HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: étape 5, image 1 de 2 HP EliteBook 8560w Keyboard Replacement, CD/DVD ROM: étape 5, image 2 de 2
    • Unscrew one M2.5x8mm screw using a Phillips #0 screwdriver.
    • The screw does not have to come out completely.
  6. HP EliteBook 8560w Keyboard Replacement: étape 6, image 1 de 3 HP EliteBook 8560w Keyboard Replacement: étape 6, image 2 de 3 HP EliteBook 8560w Keyboard Replacement: étape 6, image 3 de 3
    • Push the metal tip to the left with a screwdriver.
  7. HP EliteBook 8560w Keyboard Replacement: étape 7, image 1 de 2 HP EliteBook 8560w Keyboard Replacement: étape 7, image 2 de 2
    • Pull out the CD/DVD ROM with your hand.
  8. HP EliteBook 8560w Keyboard Replacement, Keyboard: étape 8, image 1 de 1
    • Unscrew three M2.5x8mm screws using Phillips #0 screwdriver.
  9. HP EliteBook 8560w Keyboard Replacement: étape 9, image 1 de 3 HP EliteBook 8560w Keyboard Replacement: étape 9, image 2 de 3 HP EliteBook 8560w Keyboard Replacement: étape 9, image 3 de 3
    • Put your finger through the hole to push out the keyboard from its place.
    • Keep in mind to push rather hard to fully remove the keyboard from the actual laptop.
  10. HP EliteBook 8560w Keyboard Replacement: étape 10, image 1 de 3 HP EliteBook 8560w Keyboard Replacement: étape 10, image 2 de 3 HP EliteBook 8560w Keyboard Replacement: étape 10, image 3 de 3
    • Carefully lift keyboard to reveal connection strips.
    • Unlock the latch holding the connection strips.
    • Pull out the connection strips from the motherboard.
3 autres ont terminé cette réparation.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 20
Total : 1,443
