Aller au contenu principal
HP EliteBook Folio 1020 G1 Display Replacement
Ce dont vous avez besoin
  1. Attention : les étapes 1 à 2 sont issues d'un tutoriel marqué comme étant en cours.
    HP EliteBook Folio 1020 G1 Display Replacement, Lower Case: étape 1, image 1 de 1
    • Use a TR8 Torx screwdriver to remove:
    • Six 5.3 mm screws
    • Four 3.3 mm screws
  2. HP EliteBook Folio 1020 G1 Display Replacement: étape 2, image 1 de 1
    • Use a nylon spudger to gently pry the lower case up and off.
  3. HP EliteBook Folio 1020 G1 Display Replacement, Battery: étape 3, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement, Battery: étape 3, image 2 de 2
    • Gently pull and free the battery's bundled cable connector that leads from the battery to the motherboard.
  4. HP EliteBook Folio 1020 G1 Display Replacement: étape 4, image 1 de 1
    • Use a Phillips #1 screwdriver to unscrew and remove the six 4 mm screws that secure the battery.
  5. HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: étape 5, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement, Motherboard: étape 5, image 2 de 2
    • Remove:
    • Eight 4.6 mm screws shown in the circles using Phillips #0.
  6. HP EliteBook Folio 1020 G1 Display Replacement: étape 6, image 1 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 6, image 2 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 6, image 3 de 3
    • Disconnect the keyboard connections from the motherboard.
    • Disconnect by lifting the underside of the white tabs with a spudger.
  7. HP EliteBook Folio 1020 G1 Display Replacement: étape 7, image 1 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 7, image 2 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 7, image 3 de 3
    • Disconnect circled terminals. Disconnect by lifting the underside of white tabs with spudger.
  8. HP EliteBook Folio 1020 G1 Display Replacement: étape 8, image 1 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 8, image 2 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 8, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Remove the circled tabs by pulling on the white support edges backward with a pair of tweezers.
  9. HP EliteBook Folio 1020 G1 Display Replacement: étape 9, image 1 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 9, image 2 de 3 HP EliteBook Folio 1020 G1 Display Replacement: étape 9, image 3 de 3
    • Gently pull on the black pull tab on the top of the connector.
    • For the wires going to the Wi-fi card, remove both wires going to the top of the card using the tweezers.
  10. HP EliteBook Folio 1020 G1 Display Replacement: étape 10, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement: étape 10, image 2 de 2
    • Lift the now disconnected motherboard from the side shown in image 1. This side must be lifted to not damage the ports. The disconnected motherboard (aside from port removed in step 12) is shown in image 2.
  11. HP EliteBook Folio 1020 G1 Display Replacement, Display: étape 11, image 1 de 3 HP EliteBook Folio 1020 G1 Display Replacement, Display: étape 11, image 2 de 3 HP EliteBook Folio 1020 G1 Display Replacement, Display: étape 11, image 3 de 3
    • To release the display frame from the lower frame, remove:
    • Six 4.1 mm screws using Phillips #0.
  12. HP EliteBook Folio 1020 G1 Display Replacement: étape 12, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement: étape 12, image 2 de 2
    • Once the screen is separated from the bottom frame, use a plastic opening tool to remove the bottom trim from the screen.
  13. HP EliteBook Folio 1020 G1 Display Replacement: étape 13, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement: étape 13, image 2 de 2
    • Using the iOpener and spudger, work around the screen bezel to remove it.
  14. HP EliteBook Folio 1020 G1 Display Replacement: étape 14, image 1 de 2 HP EliteBook Folio 1020 G1 Display Replacement: étape 14, image 2 de 2
    • To remove the screen, remove:
    • Four 2.2 mm screws using Phillips #0.
  15. HP EliteBook Folio 1020 G1 Display Replacement: étape 15, image 1 de 1
    • Lift display from the frame.
Steven Duke
Membre depuis le 03/28/23
121 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-1, Harley Spring 2023 Membre de l'équipe IUPUI, Team 2-1, Harley Spring 2023
IUPUI-HARLEY-S23S2G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 12
Total : 170
