Aller au contenu principal
HP EliteBook x360 830 G7 Solid State Drive Replacement
Ce dont vous avez besoin
  1. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: étape 1, image 1 de 2 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the backplate: étape 1, image 2 de 2
    • Turn the computer over so the back is facing up.
    • Use a Torx T5 screwdriver to remove the three 9 mm screws from the hinge of the device.
    • Use a Torx T5 screwdriver to remove the two 7 mm screws from the left and right mid-section of the case.
    • Lift the backplate from the computer.
  2. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the metal shield covering the SSD: étape 2, image 1 de 1
    • Lift the metal shielding off of the solid state drive.
  3. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: étape 3, image 1 de 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: étape 3, image 2 de 3 HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the screw: étape 3, image 3 de 3
    • Use a Phillips #0 screwdriver to remove the 4 mm screw that secures the SSD.
  4. HP EliteBook x360 830 G7  Solid State Drive Replacement, Remove the SSD: étape 4, image 1 de 1
    • Gently pull the SSD free from the M.2 socket.
Emily Kaplan
Membre depuis le 03/21/22
217 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 57
Total : 1,037
