Introduction
If your HP ElitePad 1000 G2 won’t turn on and you are suspecting your battery, go through these steps to eliminate the possibility of it not being charged.
If you have gone through the rest of the guide and a replacement of your battery seems to be the solution then this guide will help you fix it.
If you suspect your device has a swollen battery use this guide as reference.
Ce dont vous avez besoin
Using a Phillips #00 screwdriver, remove the two Phillips PM 1.4×3.2mm screws located next to the charging port.
Place the suction cup on the lower right corner of the tablet display glass, making sure to place the suction cup inside the edges of the border of the display glass.
Insert a plastic pick in between the display and the tablet case. Then use a plastic removal tool to separate the display further.
Pull on the suction cup while using the prying tool to separate the display from the tablet.
Locate the NFC antenna.
Release the ZIF connector to which the NFC antenna cable is attached.
Locate the power button board ribbon cable.
Locate the battery to motherboard connector.
Lift the clear tape attached to the power button board ribbon cable.
Disconnect the ZIF connector by using a plastic removal tool to gently pull up on the black tab.
Lift the power button board ribbon cable up and away so that it doesn't get in the way of the battery during removal.
7 autres ont terminé cette réparation.
