Aller au contenu principal
HP ElitePad 900 Battery Replacement
Ce dont vous avez besoin
  1. HP ElitePad 900 Battery Replacement, Front Panel Assembly: étape 1, image 1 de 1
    • Unscrew the two 2.8mm Phillips #000 screws near the power connector.
  2. HP ElitePad 900 Battery Replacement: étape 2, image 1 de 2 HP ElitePad 900 Battery Replacement: étape 2, image 2 de 2
    • Use a suction cup to pull the display assembly up.
  3. HP ElitePad 900 Battery Replacement: étape 3, image 1 de 2 HP ElitePad 900 Battery Replacement: étape 3, image 2 de 2
    • Use the tip of a spudger to disconnect the two display ZIF connectors.
  4. HP ElitePad 900 Battery Replacement, Battery: étape 4, image 1 de 1
    • Remove the six 2.2mm Phillips #000 screws securing the battery to the device.
  5. HP ElitePad 900 Battery Replacement: étape 5, image 1 de 1
    • Disconnect and move the wires out of the way.
  6. HP ElitePad 900 Battery Replacement: étape 6, image 1 de 2 HP ElitePad 900 Battery Replacement: étape 6, image 2 de 2
    • Lift cover.
  7. HP ElitePad 900 Battery Replacement: étape 7, image 1 de 2 HP ElitePad 900 Battery Replacement: étape 7, image 2 de 2
    • Slide out the battery.
13 autres ont terminé cette réparation.
Kyle Marques
Membre depuis le 09/03/15
889 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 12-4, Blackwell Fall 2015 Membre de l'équipe USF Tampa, Team 12-4, Blackwell Fall 2015
USFT-BLACKWELL-F15S12G4
4 membres
6 tutoriels rédigés
2 commentaires
Great Job took 10 min from start to finish!
Dan Goo - Réponse
One way to remove screen assembly without a suction cup is to use a piece of duct tape folded onto to itself leaving a small amount of the adhesive portion exposed. This creates a little handle. You can then stick it to assembly and lift it out easily.
Matt Brunk - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 41
Total : 12,252
