Aller au contenu principal
HP Envy 23-d060qd TouchSmart Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Back Panel: étape 1, image 1 de 1
    • Use your hands to unclip the plastic snaps on the back panel of the device.
  2. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 2, image 1 de 1
    • Remove the three 11.5mm PH2 screws from the back panel.
    • The screws will not fall out of the back panel, but they will unscrew to release the back panel.
  3. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 3, image 1 de 1
    • Now, take the back panel off by pulling at it gently with your hands.
  4. HP Envy 23-d060qd TouchSmart Hard Drive Replacement, Hard Drive: étape 4, image 1 de 1
    • Remove the one 13.5mm PH2 screw.
  5. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 5, image 1 de 1
    • Unsnap the wire mechanism to release the hard drive.
  6. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 6, image 1 de 2 HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 6, image 2 de 2
    • Detach the hard drive assembly by pulling it out of the socket.
  7. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 7, image 1 de 1
    • Remove the two 8.5mm PH2 screws on each side of the hard drive cover.
  8. HP Envy 23-d060qd TouchSmart Hard Drive Replacement: étape 8, image 1 de 1
    • Detach the hard drive cover by sliding it off from the rest of the hard drive
    • Replace the old hard drive with your new hard drive.
5 autres ont terminé cette réparation.
Zachary Dicks
Membre depuis le 10/01/15
1 135 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 5-10, Maness Fall 2015 Membre de l'équipe Cal Poly, Team 5-10, Maness Fall 2015
CPSU-MANESS-F15S5G10
4 membres
14 tutoriels rédigés
2 commentaires
Thank you so much my hard drive is bad this is going to be a quick fix and save me money you made this for dummies I LOVE IT can u tell me when I replace the hard drive will I lose everything on my computer already such as photos,files, I have everything in office purchased on the computer ? If so is there a way not to lose anything
jessica Kramer - Réponse
Yes you will, unless you back them up. All your data is stored on that hard drive.
Dane Elliott-Dyson -
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 18
30 derniers jours : 55
Total : 7,269
