Aller au contenu principal
HP Envy X2-15-C001Dx Battery Replacement
Ce dont vous avez besoin
  1. HP Envy X2-15-C001Dx Battery Replacement, Back Panel: étape 1, image 1 de 1
    • Place the laptop face down on a table.
  2. HP Envy X2-15-C001Dx Battery Replacement: étape 2, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 2, image 2 de 2
    • Lift up the back stand.
  3. HP Envy X2-15-C001Dx Battery Replacement: étape 3, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 3, image 2 de 2
    • Remove the five screws from the bottom of the back plate using a Phillips #1 screwdriver.
  4. HP Envy X2-15-C001Dx Battery Replacement: étape 4, image 1 de 1
    • Remove four screws from the back stand hinges using a Phillips #1 screwdriver.
  5. HP Envy X2-15-C001Dx Battery Replacement: étape 5, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 5, image 2 de 2
    • Remove the hinges and the back stand from the laptop.
  6. HP Envy X2-15-C001Dx Battery Replacement: étape 6, image 1 de 1
    • Use a spudger to remove the thin panel where the back stand was.
  7. HP Envy X2-15-C001Dx Battery Replacement: étape 7, image 1 de 1
    • Remove the screws from the back panel using a Phillips #1 screwdriver.
  8. HP Envy X2-15-C001Dx Battery Replacement: étape 8, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 8, image 2 de 2
    • Remove two side screws using a Phillips #1 screwdriver.
  9. HP Envy X2-15-C001Dx Battery Replacement: étape 9, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 9, image 2 de 2
    • Pry apart the base from the screen by going around the entire perimeter with an opening tool.
  10. HP Envy X2-15-C001Dx Battery Replacement: étape 10, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 10, image 2 de 2
    • Remove the back panel from the laptop.
  11. HP Envy X2-15-C001Dx Battery Replacement, Battery: étape 11, image 1 de 3 HP Envy X2-15-C001Dx Battery Replacement, Battery: étape 11, image 2 de 3 HP Envy X2-15-C001Dx Battery Replacement, Battery: étape 11, image 3 de 3
    • Unplug the battery connector from the motherboard.
  12. HP Envy X2-15-C001Dx Battery Replacement: étape 12, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 12, image 2 de 2
    • Remove the eight screws holding the battery in place using a Phillips #1 screwdriver.
  13. HP Envy X2-15-C001Dx Battery Replacement: étape 13, image 1 de 2 HP Envy X2-15-C001Dx Battery Replacement: étape 13, image 2 de 2
    • Remove the battery by simply lifting it out of the device.
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 autres ont terminé cette réparation.
Cole Escobar
Membre depuis le 10/25/21
166 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-6, Sinclaire Fall 2021 Membre de l'équipe UMass Dartmouth, Team 2-6, Sinclaire Fall 2021
UMASSD-SINCLAIRE-F21S2G6
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 333
