Introduction
Use this guide to replace the fan in an HP Envy x360 15-bp143cl. The laptop is also identified by its model number, 3TS71UAR#ABA.
Several factors can cause a laptop to overheat. Review the HP Envy x360 15-bp143cl Troubleshooting Page to check which factors may be causing the laptop to overheat. If the laptop continues to become very hot, it may be caused by a broken or faulty fan.
Turn the laptop off and disconnect it from any power supply before starting the replacement process.
Wear the Anti-Static Wrist Strap before work near the motherboard to prevent any damage.
Ce dont vous avez besoin
Remove the fan from the laptop.
During reinstallation, be sure to remove old thermal paste on both the heatsink and CPU contact points. Then, reapply thermal paste using our How to Apply Thermal Paste guide.
