Introduction
This replacement guide is for the touchpad of the HP Envy x360 m6-w103dx. The touchpad is used for moving the cursor. All you need to complete this guide is a plastic opening tool, and a #0 Phillips screwdriver.
Make sure the computer is unplugged and powered off before touching any internal parts.
Removing the touchpad is not dangerous and doesn’t require any special technical skills.
Ce dont vous avez besoin
Lift the keyboard until you can see the cables connected to the motherboard.
Gently lift the tab on each ZIF connector that connects each cable to the motherboard using a spudger. Once each tab is flipped up, the corresponding ribbon cable will come out easily.
Detach the keyboard.
