Aller au contenu principal
HP Pavilion 13-P110NR Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion 13-P110NR Keyboard Replacement, Keyboard: étape 1, image 1 de 1
    • Remove the two rubber feet closest to the black hinge.
  2. HP Pavilion 13-P110NR Keyboard Replacement: étape 2, image 1 de 2 HP Pavilion 13-P110NR Keyboard Replacement: étape 2, image 2 de 2
    • Remove two 6.0 mm Philips #00 screws from the back casing.
    • Remove four 5.0 mm Philips #00 screws from the back casing.
  3. HP Pavilion 13-P110NR Keyboard Replacement: étape 3, image 1 de 1
    • On the silver metal brace, remove the four 6.0 mm Phillips #00 screws.
  4. HP Pavilion 13-P110NR Keyboard Replacement: étape 4, image 1 de 1
    • Lift the metal brace and remove it from the device.
  5. HP Pavilion 13-P110NR Keyboard Replacement: étape 5, image 1 de 2 HP Pavilion 13-P110NR Keyboard Replacement: étape 5, image 2 de 2
    • Unflip the lock on the wire tape and lift that end of the tape away.
    • Do the same for the small white piece of tape on the circuit board.
  6. HP Pavilion 13-P110NR Keyboard Replacement: étape 6, image 1 de 2 HP Pavilion 13-P110NR Keyboard Replacement: étape 6, image 2 de 2
    • Remove the eight 6.0 mm Philips #00 screws from the two silver holds.
  7. HP Pavilion 13-P110NR Keyboard Replacement: étape 7, image 1 de 1
    • Remove five 5.0 mm Philips #00 screws from the green circuit boards.
  8. HP Pavilion 13-P110NR Keyboard Replacement: étape 8, image 1 de 3 HP Pavilion 13-P110NR Keyboard Replacement: étape 8, image 2 de 3 HP Pavilion 13-P110NR Keyboard Replacement: étape 8, image 3 de 3
    • Lift the white pieces up.
    • Once lifted, peel the black film away to reveal a metal plate with many black glue pieces.
  9. HP Pavilion 13-P110NR Keyboard Replacement: étape 9, image 1 de 1
    • Using the spudger, pry each glue piece off of the metal brace. All glue pieces must be removed.
    • Use caution, the pieces may fly when they are forced out.
  10. HP Pavilion 13-P110NR Keyboard Replacement: étape 10, image 1 de 1
    • Remove the metal plate to reveal the keyboard.
  11. HP Pavilion 13-P110NR Keyboard Replacement: étape 11, image 1 de 2 HP Pavilion 13-P110NR Keyboard Replacement: étape 11, image 2 de 2
    • Remove the keyboard from the device.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 312
