Introduction
HP Pavilion 14-v062us Keyboard
If your HP Pavilion 14-b120dx laptop has sticky keys, missing components, or an overall malfunctioning keyboard, it might be time to replace the keyboard. This operation isn’t as hard as one may think. In fact, with the right materials, you can tackle this job in just a few steps.
For precise instructions, use this guide to replace the keyboard. This guide will show you how to replace the keyboard on your HP Pavilion 14-v062us. Before starting, make sure your device is turned off and disconnected from any power sources. Transfer your laptop to a stable, dry, working surface to begin the operation. The installation process is just the reverse order of the removal process.
Ce dont vous avez besoin
Push inward towards the center of laptop (it may take a lot of pressure). Battery should release once buttons are completely pushed in
Remove rectangular rubber tops with a spudger
Remove the two 4.60 mm PH#1 screws located under rectangular rubber tops.
Remove plastic edge covering with the blue plastic opening tool.
Remove two 4.63 mm PH#1 screws located under plastic edge covering.
2 autres ont terminé cette réparation.
2 commentaires
Thank you so much, this guide is very helpful.
