Aller au contenu principal
HP Pavilion 15-ba003ds Thermal Paste Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Battery: étape 1, image 2 de 2
    • Unplug the AC adapter from the corresponding socket in the laptop.
    • Turn off your laptop before starting this procedure. Make sure it's not in sleep or hibernation mode.
    • Use your fingers to push the slider located just under the battery on either side to unlock the battery from the laptop.
    • Carefully slide the battery out of the laptop frame and place it somewhere safe.
  2. HP Pavilion 15-ba003ds Thermal Paste Replacement, Disc Drive: étape 2, image 1 de 1
    • Remove the two rubber feet next to the battery.
  3. HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 3, image 1 de 2 HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 3, image 2 de 2
    • Remove twelve 8mm Phillips #00 screws including two underneath the rubber feet.
  4. HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 4, image 1 de 2 HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 4, image 2 de 2
    • Pull out the disc drive by hand.
  5. HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: étape 5, image 1 de 3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: étape 5, image 2 de 3 HP Pavilion 15-ba003ds Thermal Paste Replacement, Backplate: étape 5, image 3 de 3
    • Use a Jimmy to pry off the black backplate.
  6. HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: étape 6, image 1 de 2 HP Pavilion 15-ba003ds Thermal Paste Replacement, Thermal Paste: étape 6, image 2 de 2
    • Remove four 3mm Phillips #00 screws holding the CPU heatsink in place.
  7. HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 7, image 1 de 3 HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 7, image 2 de 3 HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 7, image 3 de 3
    • Gently wiggle and remove CPU heatsink.
    • Do not attempt to pull the heatsink away without having wiggled it, as it may cause damage to your motherboard.
    • Wiggle while holding the heatink on top of the CPU, not the fan housing.
  8. HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 8, image 1 de 2 HP Pavilion 15-ba003ds Thermal Paste Replacement: étape 8, image 2 de 2
    • Generously apply the 99% isopropyl alcohol to your microfiber cloth.
    • Make sure that the thermal paste is completely wiped away and that the processor is dry
    • Apply a small pea sized amount of thermal paste to the processor.
    • Ensure that when you’re wiping away the old thermal paste that none of it falls onto the motherboard beneath it.
2 autres ont terminé cette réparation.
Joseph Chia
Membre depuis le 01/14/20
355 Réputation
3 tutoriels rédigés
Équipe
York University, Team S1-G9, Woodhouse Winter 2020 Membre de l'équipe York University, Team S1-G9, Woodhouse Winter 2020
YORK-WOODHOUSE-W20S1G9
3 membres
8 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 33
Total : 2,283
