Aller au contenu principal
HP Pavilion 15-cd040wm Hard Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: étape 1, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement, HP Pavilion 15-cd040wm Back Cover Disassembly: étape 1, image 2 de 2
    • The first step is to remove the four rubber non-slip pads on the bottom of the laptop to expose screws hidden underneath them. Peel off each tab with your fingers.
    • If you have trouble gripping a tab, use a spudger to wedge it loose.
  2. HP Pavilion 15-cd040wm Hard Drive Replacement: étape 2, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement: étape 2, image 2 de 2
    • 3x 10mm Phillips scews
    • 2x 5mm Phillips screws
    • 6x 6mm Phillips screws
    • Remove all screws using a size Phillips #0 screwdriver.
  3. HP Pavilion 15-cd040wm Hard Drive Replacement: étape 3, image 1 de 3 HP Pavilion 15-cd040wm Hard Drive Replacement: étape 3, image 2 de 3 HP Pavilion 15-cd040wm Hard Drive Replacement: étape 3, image 3 de 3
    • Using the iFixit opening tool, carefully pry along the sides of the back cover.
    • After all of the edges of the back cover have been freed, use your opening tool to carefully unclip the tabs holding the back cover to the CD drive.
    • After everything is unclipped, you can safely remove the back cover from the rest of the device.
  4. HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: étape 4, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement, Battery: étape 4, image 2 de 2
    • 2x 5mm Philips screws
    • 2x 3mm Philips screws
  5. HP Pavilion 15-cd040wm Hard Drive Replacement: étape 5, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement: étape 5, image 2 de 2
    • Gently pull up on the battery and tilt it away from the rest of the laptop chassis.
    • Pull out the battery at an angle and lift it out of the laptop.
  6. HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: étape 6, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement, Hard Drive: étape 6, image 2 de 2
    • Using a spudger or the opening tool, lift the end closest to the battery until you can hold the hard drive with your hands.
  7. HP Pavilion 15-cd040wm Hard Drive Replacement: étape 7, image 1 de 2 HP Pavilion 15-cd040wm Hard Drive Replacement: étape 7, image 2 de 2
    • Carefully remove the connector ribbon cable from the elevated end of the hard drive, then remove the hard drive.
2 autres ont terminé cette réparation.
Brian Cornet
Membre depuis le 10/21/19
316 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G1, Botvin Fall 2019 Membre de l'équipe UMass Dartmouth, Team S1-G1, Botvin Fall 2019
UMASSD-BOTVIN-F19S1G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 31
Total : 1,673
