Aller au contenu principal
HP Pavilion 15-e043cl Optical Drive Replacement
Ce dont vous avez besoin
  1. HP Pavilion 15-e043cl Optical Drive Replacement, Battery: étape 1, image 1 de 2 HP Pavilion 15-e043cl Optical Drive Replacement, Battery: étape 1, image 2 de 2
    • Flip the device over.
    • Slide the battery switch on the right half of the laptop.
    • Make sure the device is powered off, and that it is not connected to any power sources.
  2. HP Pavilion 15-e043cl Optical Drive Replacement: étape 2, image 1 de 2 HP Pavilion 15-e043cl Optical Drive Replacement: étape 2, image 2 de 2
    • Lift the battery up and out of the device by the inward-facing edge.
  3. HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: étape 3, image 1 de 3 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: étape 3, image 2 de 3 HP Pavilion 15-e043cl Optical Drive Replacement, Maintenance Panel: étape 3, image 3 de 3
    • Unscrew the single Phillips #0 captive screw that was previously hidden by the battery.
    • The screw can not, and should not, be fully removed.
    • Slide the maintenance panel away from the battery compartment to release it.
  4. HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: étape 4, image 1 de 2 HP Pavilion 15-e043cl Optical Drive Replacement, Optical Drive: étape 4, image 2 de 2
    • Remove the black screw nearby to the disk tray.
    • Push the disk tray out of the laptop near the stamp that says "RELEASE."
Cace Letendre
Membre depuis le 10/25/22
519 Réputation
6 tutoriels rédigés
Équipe
UMass Dartmouth, Team 4-5, Sinclaire Fall 2022 Membre de l'équipe UMass Dartmouth, Team 4-5, Sinclaire Fall 2022
UMASSD-SINCLAIRE-F22S4G5
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 5
Total : 105
