Introduction
WARNING: The computer should be off (no power running), unplugged and the battery must be removed to prevent electrical shock.
This guide will assist you in replacing the fan in the HP Pavilion 15-n210dx. It is more lengthy than the other guides due to some prerequisites, but the steps should keep you on track to removing and replacing the fan.
The fan is an essential component of a laptop. It draws in cooler air into the computer, while pushing the warm air out of the computer. This ensure the computer’s internal components stay cool and continue to function normally. If the fan starts to get loud dust buildup is likely the culprit. Refer to the fan part of the troubleshooting page to clean out the fan and the vents.
You should have a Y0 screwdriver and a metal spudger with you before starting the replacement of the fan.
Ce dont vous avez besoin
Turn over the laptop and remove the single screw using a Tri-point Y0 screwdriver.
Use the Tri-point Y0 screwdriver to remove all the screws on the metal sheet.
