Wiki réalisé avec l'aide d'étudiants
Une formidable équipe d’étudiants de notre programme éducatif a créé ce wiki.
Blue Screen of Death is Present
Blue screen of death occurs when the computer powers up or at random times when the computer is in use. This is known as the blue screen of death (BSOD)
Incompatible software
Let the computer restart on its own. The computer will try to troubleshoot the problem. If initial troubleshooting by computer does not resolve the issue Safe Mode must be accessed in order for additional troubleshooting: Hold down the power button for 10 seconds to shut down your computer > Press the power button again to turn on your device > On the first sign that Windows has started (most likely the manufacturer logo will appear) hold down the power button for 10 seconds to shut down computer > Press the power button again to turn on your computer > When Windows restarts, hold down the power button for 10 seconds to turn off your computer > Press the power button again to turn on your computer > Allow your computer to fully restart > Choose an option screen shows up > Troubleshoot > Advanced options > Startup settings > Restart > after restart > press 4 to enter Safe Mode without internet or 5 with internet > scan for malware and viruses using antivirus application > Run System Restore to restore to previous stable version > Uninstall recently installed software > Update drivers > Uninstall unnecessary apps. If blue screen continues to occur, the hardware could be faulty, and thus the mother board must be replaced. Follow this gude to replace the motherboard.
Driver Space is Full/Not Enough Room Available
Ensure the driver space is not close to being full. If so, clear up space by deleting unneeded software and files. The following will guide you to this goal: Enter settings > change pc settings > pc and devices > disk space > free up space on this PC. Additional steps: click on “See my app sizes” to determine which app(s) to delete. Click on the Recycle Bin to decide on which files should be removed from the driver space.
Malware
Malware may be difficult to be removed when the computer is not in Safe Mode. Run a full scan using your antivirus software. This must be done in Safe Mode.
Hardware is Not up to Date
Download the most current hardware device from the manufacturer’s website. Make sure your computer is in Safe Mode before starting.
Computer Will Not Turn On
The computer does not start and emit an LED
Insufficient Amount of Power
Press the power button to repeat the blinking sequence. Next look at the battery light LED which is generally a lightning bold icon. If the battery light LED flashes, the battery has insufficient charge to start the computer. Due to this, charge the computer up. While its plugged in, attempt to start the computer up. If the AC adapter features an LED power indicator, check if the AC adapter LED illuminates. Charge the battery for about thirty minutes to one hour. Lastly restart the computer.
Faulty Battery
Perform a battery test to analyze the health of the battery. Turn on the computer and search for HP PC Hardware Diagnostics Windows. Right-click the app in the search results and select “Run as administrator”. Next, Click “Component Test” in the main menu. In the list of Component Tests, click “Power”. Then, Select “Battery Check” , and then click “Run once”. Wait while the test is running, usually takes about two minutes. Click “Finish” on the Components page. Then, select “Tests Logs” to see the results on the battery test. Review the “Test Logs” that display the condition of the battery. If your battery passed click “Main Menu” or “Details” for more information. If your battery didn’t pass, check the information table in the Test Logs section on the main menu to access further information in regard to your battery test results. If the status of your battery test result appears as “Replace”, the battery reports a failure and needs to be replaced. Thus, follow the following instructions to replace the battery.
Key(s) on the Keyboard do not Work or are Missing
Certain keys will not respond when pressed or are damaged or missing
Defective Keyboard
Replacing individual keys should be considered first before trying to replace the entire keyboard. Purchase a HP Pavilion 15 series keyboard. It can be purchased from online sources such as Amazon at an affordable price. Certain keys that you need to replace the missing or damaged keys on original keyboard will come from the newly purchased keyboard. Have a flat head screwdriver ready to be used. The smaller the head the better. The following will help you remove a key: Slide the screwdriver under a key of interest as deep as possible > as the key comes up at an angle, remove the key using your thumb and index finger while keeping the screwdriver flat on the keyboard to hold down the retainer clip that is underneath the key > remove the retainer clip (it has two parts but it can be removed as whole) by inserting the screw driver underneath the right side part of the clip while holding down the top part of the clip and slide the screw driver underneath the side of the clip to the bottom of the clip to maximize the chance of extraction (Attempt to avoid any damage at all to the clip or the pins that hold down the clip onto the keyboard). Next, the following will guide you on how to put a key back on: Line up the holes on the interior part of clip to the upper two pins and slid it onto it > line up the bottom holes to the lower two pins and push the corner down (you should hear a snap when this is done) > retrieve the key that belongs in that slot > center the key as much as possible > push the key down (it should snap into place, sometimes you have to push it down a couple times or so to ensure it is snaped back in). If the keyboard does not work at all, attempt to follow this guide.
Fan Will not work or it spins fast often
The fan does not respond when the computer runs or it is very loud due to high speeds.
Lack of Air Flow
Ensure the computer is on a flat and cool surface. 2-3 inches of space should surround the computer. In addition, the ideal temperature of the setting where the computer is used should be close to room temperature of 72 degrees Fahrenheit.
Dust Buildup
Power off the computer and unplug the computer if it is plugged in. The computer should have no power running through it. Use an air canister to blow away dust build up by inserting the nozzle in between the grates that holds the fan. To ensure all dust is removed, follow the guide that involves the replacement of the fan and use the canister to remove the rest of the dust as best as possible. Replacing the fan itself is not necessary unless unforeseen damages to the fan is present or removal of dust does not resolve the problem. Turn the computer back on and notice if there is a diminution in the fan speed.
Files are Disappearing
You are not able to retrieve files that you know you had
Insufficient Hard Drive Space
Press the windows button on the keyboard and then search Storage Settings, the amount of storage left on the device will be displayed and if is full try deleting excess files or games from the device
Malfunctioning Hard Drive
Restart the laptop by holding down the power button 5 seconds until the power shuts off, and then turn the computer back on. If this does not resolve the issue proceed to the next suggestion: HP hard drive self test. Hold down the power button for 5 seconds until the power shuts off. Turn the laptop back on then repeatedly press f10 to bring up windows BIOS menu. Use keyboard arrows to navigate to Primary Hard Drive Self Test. The system will perform a hard drive test. If any test fails, order a replacement battery and follow this guide.
Hard Drive Is Defective
If the hard drive is creating a clicking noise, or none of the above solutions have worked the Hard Drive is most likely broken. Follow this guide on how to replace it.
Sound is not Working / Sound is Static
You are not able to listen to sound on your computer or if sound does occur, it is static
Audio Driver is Out of Date
Automatically update the laptop drivers by the following steps. Hold down the power button for 5 seconds until the laptop shuts down, then turn it back on. Restarting the laptop will allow windows to automatically update its drivers.
Manually update drivers by going to Windows Device Manager > Sound, video and game controllers section. In the list of audio device drivers, look for Realtek High Definition Audio or Conexant. Right-click and select Disable. The downward arrow displays on this driver, indicating it is disabled. Then Right-click and select Update Driver Software. Select Browse my computer for driver software. Select Let me pick from a list of device drivers on my computer. You should see a window that says Select the device driver you want to install for this hardware. If you see a window that says something like This is the best driver for this device, exit the window and repeat steps 4, 5, and 6. In the Model box, highlight High Definition Audio Device and click Next. At the Update Driver Warning window, click Yes. You should see a confirmation window with High Definition Audio Device displayed. Click Close. In the list of audio device drivers in the Sound, video and game controllers section, you’ll notice that the High Definition Audio Device now displays instead of Realtek High Definition Audio. At the prompt to reboot, click Yes. Then see if speakers are working
Clean the Headphone Jack
Locate the headphone jack on the laptop and use a flashlight to look inside while the laptop is off. If there is any debris try blowing inside the headphone jack or cleaning it with a small needle (a small air compressor can also be used to clean the jack if available).
Speakers are Defective or no Longer Work
If speakers are not working after testing the audio driver the speakers will have to be replaced using this guide.
0 commentaires
