Aller au contenu principal
HP Pavilion 17-e146us Screen Replacement
Ce dont vous avez besoin
  1. HP Pavilion 17-e146us Screen Replacement, Screen: étape 1, image 1 de 2 HP Pavilion 17-e146us Screen Replacement, Screen: étape 1, image 2 de 2
    • Open the laptop.
    • Remove the two stickers on the lower left and right-hand corner of the laptop screen.
  2. HP Pavilion 17-e146us Screen Replacement: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the two 5 mm screws in the lower left and right-hand corner of the laptop screen.
  3. HP Pavilion 17-e146us Screen Replacement: étape 3, image 1 de 2 HP Pavilion 17-e146us Screen Replacement: étape 3, image 2 de 2
    • Place a spudger or opening tool between the laptop screen and the plastic laptop frame.
    • Apply light pressure to the spudger to separate the plastic laptop frame covering the edges of the laptop screen.
    • These silver pieces cover the laptop hinges and will need to be removed as well.
  4. HP Pavilion 17-e146us Screen Replacement: étape 4, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the four 4 mm screws in each corner of the laptop screen.
    • This will separate the laptop cover from the laptop screen frame.
    • Hold the laptop cover securely to prevent damage.
  5. HP Pavilion 17-e146us Screen Replacement: étape 5, image 1 de 2 HP Pavilion 17-e146us Screen Replacement: étape 5, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the four 3 mm screws on the side of the frame, one in each corner.
    • This will release the laptop screen from the frame.
    • Hold the laptop screen and frame securely to prevent damage to the motherboard attachments.
  6. HP Pavilion 17-e146us Screen Replacement: étape 6, image 1 de 2 HP Pavilion 17-e146us Screen Replacement: étape 6, image 2 de 2
    • Remove laptop screen.
    • While removing the laptop screen, be careful not to destroy the tape connection or break the motherboard.
Emma Neumann
Membre depuis le 09/04/19
629 Réputation
5 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 13
Total : 472
