Aller au contenu principal
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
Ce dont vous avez besoin
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 3, image 1 de 1
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 4, image 1 de 1
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 6, image 1 de 1
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
3 autres ont terminé cette réparation.
Robert Hemphill
Membre depuis le 01/22/15
278 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-22, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 membres
6 tutoriels rédigés
Un commentaire
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 8
Total : 1,711
