Aller au contenu principal
HP Pavilion Touchsmart 11z-e000 Keyboard Replacement
Robert Hemphill
Robert Hemphill et 5 autres contributeurs
Dernière mise à jour le June 17, 2015
20 - 35 minutes
Difficile
Problème de balise
Étapes manquantes
If your keyboard is missing keys, sticky, or the keyboard is not responding you may need to replace your keyboard. This guide will cover how to remove the keyboard for replacement.
Ce dont vous avez besoin
Outils
Afficher plus…
  1. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Remove battery by pushing the two tabs and pulling the battery outwards slowly but firmly.
  2. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement, Keyboard: étape 2, image 1 de 1
    • Use a spudger to slide under the outer plastic cover of the laptop and lift it up and away.
    • Pull off the plastic cover of the laptop.
  3. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 3, image 1 de 1
    • Remove all of the silver screws connecting the keyboard plate to the rest of the laptop.
    • This step allows the top plate to be removed from the body of the laptop in the following step.
    12- M2x4 screws to remove. And it helps to remove the screws holding the elbow because it releases the front plate at the top corners.
    Con Fran - Réponse
  4. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 4, image 1 de 1
    • Use a spudger to lift the keyboard plate off of the base of the computer.
    • Some areas near the hinges may be connected with an adhesive. Take care when removing the plate in these regions.
  5. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 5, image 1 de 1
    • Remove the screws connecting the keyboard to the underside of the plate
    • Detach the ribbon wire connecting the keyboard to the hardware.
    • This picture shows the underside of the keyboard after it is removed from the laptop.
  6. HP Pavilion Touchsmart 11z-e000 Keyboard Replacement: étape 6, image 1 de 1
    • Slowly separate the main part of the keyboard from the metal plate by pressing firmly on the key side of the keyboard and lifting from the back side.
3 autres ont terminé cette réparation.
Robert Hemphill
Membre depuis le 01/22/15
278 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 21-22, Maness Winter 2015 Membre de l'équipe Cal Poly, Team 21-22, Maness Winter 2015
CPSU-MANESS-W15S21G22
4 membres
6 tutoriels rédigés
1 commentaire de tutoriel
Where can I find a replacement keyboard for the hp pavilion ts 11-e110nr? I've tried a basic search and also Amazon and eBay, but I can't find one anywhere.
Con Fran - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,723
