Aller au contenu principal
HP Pavilion x360 11-p110nr Battery Replacement
Ce dont vous avez besoin
  1. HP Pavilion x360 11-p110nr Battery Replacement, Battery: étape 1, image 1 de 2 HP Pavilion x360 11-p110nr Battery Replacement, Battery: étape 1, image 2 de 2
    • First, unplug the power cord from the power outlet and disconnect the charger.
    • Flip over the laptop.
    • Unscrew the back cover using the Phillips #0 screwdriver.
    • Deattach the cover carefully and do not remove the cover completely as there is a safety plastic that needs to be removed first.
    • Remove the blue safety plastic in an orthogonal motion from where it is inserted carefully.
  2. HP Pavilion x360 11-p110nr Battery Replacement: étape 2, image 1 de 2 HP Pavilion x360 11-p110nr Battery Replacement: étape 2, image 2 de 2
    • Remove the five 1 mm screws connecting the battery to the base of the computer using a Phillips #0 screwdriver.
  3. HP Pavilion x360 11-p110nr Battery Replacement: étape 3, image 1 de 1
    • Carefully disconnect the three connectors by pulling them away from the slot.
    • If they seem hard to pull, try to wiggle them loose to making it easier to pull.
    • Pull out the battery after everything is disconnected.
AljeannaJohnson
Membre depuis le 09/20/17
202 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 4
30 derniers jours : 11
Total : 588
