Aller au contenu principal
HP Stream 11-y010nr Battery Replacement
Ce dont vous avez besoin
  1. HP Stream 11-y010nr Battery Replacement, Keyboard: étape 1, image 1 de 3 HP Stream 11-y010nr Battery Replacement, Keyboard: étape 1, image 2 de 3 HP Stream 11-y010nr Battery Replacement, Keyboard: étape 1, image 3 de 3
    Outil utilisé dans cette étape :
    J'achète
    • Gently peel back the two rubber strips that cover the screws on backside of the computer with the needle nose tweezers.
    • Ensure the laptop is turned off.
  2. HP Stream 11-y010nr Battery Replacement: étape 2, image 1 de 2 HP Stream 11-y010nr Battery Replacement: étape 2, image 2 de 2
    • Unscrew the seven 0.4mm screws on the backside of the laptop with the Phillips #0 Screwdriver.
  3. HP Stream 11-y010nr Battery Replacement: étape 3, image 1 de 2 HP Stream 11-y010nr Battery Replacement: étape 3, image 2 de 2
    • Take the opening picks and push them into the seam between the keyboard and the laptop casing.
    • Go all the way around the laptop.
  4. HP Stream 11-y010nr Battery Replacement: étape 4, image 1 de 1
    • Once the cover is loose enough, lift the keyboard up to expose the wiring beneath.
    • Be careful not to pull too hard or fast as there are ribbon cables attached to the keyboard and trackpad.
  5. HP Stream 11-y010nr Battery Replacement: étape 5, image 1 de 3 HP Stream 11-y010nr Battery Replacement: étape 5, image 2 de 3 HP Stream 11-y010nr Battery Replacement: étape 5, image 3 de 3
    • Disconnect the three cables by lifting up on the locking tab of the ZIF connector and pulling the cables out with the needle nose tweezers.
    • Remove the keyboard.
  6. HP Stream 11-y010nr Battery Replacement, Battery: étape 6, image 1 de 3 HP Stream 11-y010nr Battery Replacement, Battery: étape 6, image 2 de 3 HP Stream 11-y010nr Battery Replacement, Battery: étape 6, image 3 de 3
    • Use your fingers or a spudger to pull the battery cable out from its connector.
  7. HP Stream 11-y010nr Battery Replacement: étape 7, image 1 de 2 HP Stream 11-y010nr Battery Replacement: étape 7, image 2 de 2
    • Unscrew the six 0.4mm screws surrounding the battery with a Phillips #1 screwdriver.
  8. HP Stream 11-y010nr Battery Replacement: étape 8, image 1 de 3 HP Stream 11-y010nr Battery Replacement: étape 8, image 2 de 3 HP Stream 11-y010nr Battery Replacement: étape 8, image 3 de 3
    • Carefully lift up on the battery.
    • If the black and white wire on the bottom is intertwined with the bracket, gently pull the wire off the battery.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 68
Total : 3,208
