Aller au contenu principal
HP Stream 13-c010nr Wi-Fi Card Replacement
Ce dont vous avez besoin
  1. HP Stream 13-c010nr Wi-Fi Card Replacement, HP Stream 13-c010nr Disassembly: étape 1, image 1 de 1
    • Remove the five rubber feet from the bottom of the laptop with a plastic opening tool.
  2. HP Stream 13-c010nr Wi-Fi Card Replacement: étape 2, image 1 de 2 HP Stream 13-c010nr Wi-Fi Card Replacement: étape 2, image 2 de 2
    • Remove the thirteen 5mm Phillips #0 screws from the bottom case.
  3. HP Stream 13-c010nr Wi-Fi Card Replacement: étape 3, image 1 de 2 HP Stream 13-c010nr Wi-Fi Card Replacement: étape 3, image 2 de 2
    • Flip the laptop over and open it up.
    • Wedge a plastic opening tool between the keyboard and bottom case, pry upwards to separate the two pieces.
    • Lift up the keyboard.
    • Ribbon cables still connect the two pieces.
  4. HP Stream 13-c010nr Wi-Fi Card Replacement: étape 4, image 1 de 1
    • Use a spudger to flip up the retaining flaps on the keyboard ribbon cable ZIF sockets.
    • Pull up the ribbon cables from their sockets.
  5. HP Stream 13-c010nr Wi-Fi Card Replacement, Wi-Fi Card: étape 5, image 1 de 1
    • Slide the Wi-Fi card out from the motherboard.
Keegan Lapham
Membre depuis le 02/22/18
759 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team S1-G3, Cagle Spring 2018 Membre de l'équipe USF Tampa, Team S1-G3, Cagle Spring 2018
USFT-CAGLE-S18S1G3
4 membres
12 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 13
Total : 284
