Introduction
Take five minutes to replace a damaged headphone jack (also known as port) in a HTC Desire 826 cellphone. With pictures and many guided steps. It may be beneficial to refer to the "HTC Desire 825 Battery Replacement" guide. You will also need four tools, 1 T5 Torx Screwdriver, 1 Tweezer, 1 Magnetic Project Mat, and 1 Spudger to complete this task. The costs of tools all together is roughly about $35 dollars.
Ce dont vous avez besoin
Find a seam in the back of the device.
Insert the plastic spudger into the seam and pry off the back panel.
Use the T5 screwdriver to remove the three 4.00 mm screws as shown.
Once the screws are removed, pry up the top plastic panel using the black nylon spudger.
