Aller au contenu principal
HTC One Speaker Replacement
Ce dont vous avez besoin
  1. HTC One Speaker Replacement, Speaker: étape 1, image 1 de 3 HTC One Speaker Replacement, Speaker: étape 1, image 2 de 3 HTC One Speaker Replacement, Speaker: étape 1, image 3 de 3
    • Gently remove the volume button. Using a plastic opening tool or guitar pick, loosen the back panel of the phone. Work around the phone, following the crease of the back panel.
  2. HTC One Speaker Replacement: étape 2, image 1 de 1
    • Pry the back loose and lift. The back panel will come off with time.
  3. HTC One Speaker Replacement: étape 3, image 1 de 1
    • Remove all of the screw which are located on the backside of the phone with a #000 Phillip screw driver.
    • Remove the tape gently to find some hidden screws underneath.
  4. HTC One Speaker Replacement: étape 4, image 1 de 1
    • Use tweezers to get underneath the motherboard to lift.
    • Lift gently because the motherboard is not completely disconnected.
  5. HTC One Speaker Replacement: étape 5, image 1 de 1
    • Remove the Camera by detaching the box from the frame (you will have to rotate the metal piece on the box to remove it)
    • Lift the camera from the bottom of the motherboard.
  6. HTC One Speaker Replacement: étape 6, image 1 de 2 HTC One Speaker Replacement: étape 6, image 2 de 2
    • Remove the motherboard completely out of the phone.
    • May stay attached from one end by tape.
  7. HTC One Speaker Replacement: étape 7, image 1 de 2 HTC One Speaker Replacement: étape 7, image 2 de 2
    • Use the blue opening tool to pry the battery from the frame.
    • Some force will be needed since the battery is glued to the frame.
    • Be careful to not break the battery upon removal.
  8. HTC One Speaker Replacement: étape 8, image 1 de 3 HTC One Speaker Replacement: étape 8, image 2 de 3 HTC One Speaker Replacement: étape 8, image 3 de 3
    • Completely remove the motherboard.
  9. HTC One Speaker Replacement: étape 9, image 1 de 2 HTC One Speaker Replacement: étape 9, image 2 de 2
    • Remove the #000 screws around the speaker that are located at the bottom of the frame.
    • Lift the speaker out of the frame.
16 autres ont terminé cette réparation.
Alex
Membre depuis le 09/23/14
664 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 12-1, Blackwell Fall 2014 Membre de l'équipe USF Tampa, Team 12-1, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G1
4 membres
7 tutoriels rédigés
2 commentaires
Ok I will good
Raguraman - Réponse
Where to buy speaker???
bharatdshmkh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 2
30 derniers jours : 9
Total : 19,351
