Aller au contenu principal
Pour réparer ensemble - Je crée un compte
HTC Vive XR Elite Right Speaker Replacement
Ce dont vous avez besoin
  1. HTC Vive XR Elite Right Speaker Replacement, Prepare your Vive XR Elite for disassembly: étape 1, image 1 de 1
    • Before starting this repair, discharge the batteries in your headset below 25%. A charged battery may leak dangerous chemicals or catch fire if damaged.
    • Playing Half Life: Alyx will do the trick!
    • The Vive XR Elite has a proximity sensor that puts the headset in standby mode to save battery when it isn't in use. To drain the battery faster you'll need to use the headset.
    Demander à FixBot
    Ajouter un commentaire
  2. HTC Vive XR Elite Right Speaker Replacement, Disconnect the USB-C power cable: étape 2, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Disconnect the USB-C power cable: étape 2, image 2 de 2
    • Disconnect the USB-C power cable.
    Demander à FixBot
  3. HTC Vive XR Elite Right Speaker Replacement, Disconnect the battery cradle: étape 3, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Disconnect the battery cradle: étape 3, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Disconnect the battery cradle: étape 3, image 3 de 3
    • Press the release button on the right battery cradle temple slot.
    • Pull the battery cradle away from the right temple slot to disconnect it.
    Demander à FixBot
  4. HTC Vive XR Elite Right Speaker Replacement: étape 4, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 4, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 4, image 3 de 3
    • Repeat the previous step for the left temple slot.
    Demander à FixBot
  5. HTC Vive XR Elite Right Speaker Replacement, Separate the headset and battery cradle: étape 5, image 1 de 1
    • Separate the headset and battery cradle.
    Demander à FixBot
  6. HTC Vive XR Elite Right Speaker Replacement, Remove the face cushion: étape 6, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the face cushion: étape 6, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the face cushion: étape 6, image 3 de 3
    • The face cushion is attached to the headset with two magnets. You'll feel the pull of the magnets as you remove it.
    • Grip the middle of the face cushion with your fingers and pull back to remove it.
    Demander à FixBot
  7. HTC Vive XR Elite Right Speaker Replacement, Remove the screw covers: étape 7, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Remove the screw covers: étape 7, image 2 de 2
    Outil utilisé dans cette étape :
    • Use tweezers to remove the six screw covers from the right temple.
    Demander à FixBot
  8. HTC Vive XR Elite Right Speaker Replacement, Unfasten the right temple: étape 8, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Unfasten the right temple: étape 8, image 2 de 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two right temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the right hinge cover.
    Demander à FixBot
  9. HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 9, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 9, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 9, image 3 de 3
    • Insert the flat end of a spudger in the gap between the right outer and inner hinge covers.
    • Slide the spudger along the gap to separate the clips securing the outer hinge cover.
    • Remove the outer hinge cover.
    Demander à FixBot
  10. HTC Vive XR Elite Right Speaker Replacement, Remove the outer temple: étape 10, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer temple: étape 10, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer temple: étape 10, image 3 de 3
    • Insert the flat end of a spudger in the gap between the outer and inner temple.
    • Slide the spudger along the gap to separate the clips securing the outer temple.
    Demander à FixBot
  11. HTC Vive XR Elite Right Speaker Replacement: étape 11, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 11, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 11, image 3 de 3
    • Slide the top of the outer temple out of its slot in the hinge.
    Demander à FixBot
  12. HTC Vive XR Elite Right Speaker Replacement: étape 12, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 12, image 2 de 2
    Tesa 61395 Tape
    $10.95
    • The speaker is lightly adhered to the outer temple.
    • Rotate the outer temple towards you to access the speaker.
    • Slide the flat end of a spudger under the speaker to separate its adhesive.
    • During reassembly, if your speaker adhesive isn't sticky, use double-sided tape to re-adhere the speaker to the outer temple.
    Demander à FixBot
  13. HTC Vive XR Elite Right Speaker Replacement: étape 13, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 13, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement: étape 13, image 3 de 3
    • Thread the outer temple off of the USB‑C cable and remove it.
    Demander à FixBot
  14. HTC Vive XR Elite Right Speaker Replacement: étape 14, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 14, image 2 de 2
    • Pull the inner temple out of its slot in the hinge and remove it.
    Demander à FixBot
  15. HTC Vive XR Elite Right Speaker Replacement, Peel the hinge tape: étape 15, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Peel the hinge tape: étape 15, image 2 de 2
    • Use tweezers to peel back the black tape covering one of the inner hinge cover screws.
    Demander à FixBot
  16. HTC Vive XR Elite Right Speaker Replacement, Unfasten the inner hinge cover: étape 16, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two screws securing the inner hinge cover:
    • One 3.1 mm‑long screw
    • One 4.9 mm‑long screw
    Demander à FixBot
  17. HTC Vive XR Elite Right Speaker Replacement, Remove the inner hinge cover: étape 17, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the inner hinge cover: étape 17, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the inner hinge cover: étape 17, image 3 de 3
    • Rotate the inner hinge cover off its groove in the frame.
    • Thread the inner hinge cover off of the USB-C and speaker cables and remove it.
    Demander à FixBot
  18. HTC Vive XR Elite Right Speaker Replacement, Remove the screw covers: étape 18, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Remove the screw covers: étape 18, image 2 de 2
    • Use tweezers to remove the six screw covers from the left temple.
    Demander à FixBot
  19. HTC Vive XR Elite Right Speaker Replacement, Unfasten the left temple: étape 19, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Unfasten the left temple: étape 19, image 2 de 2
    • Use a T5 Torx screwdriver to remove the six 4.9 mm‑long screws securing the two left temple halves.
    • Use a T5 Torx screwdriver to remove the two 3.5 mm‑long screws securing the left hinge cover.
    Demander à FixBot
  20. HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 20, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 20, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Remove the outer hinge cover: étape 20, image 3 de 3
    • Insert the flat end of a spudger in the gap between the left outer and inner hinge covers.
    Demander à FixBot
  21. HTC Vive XR Elite Right Speaker Replacement, Remove the left temple: étape 21, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Remove the left temple: étape 21, image 2 de 2
    • Pull the left temple out of its slot in the hinge.
    • Don't try to fully remove it yet, as it's still connected by a cable.
    Demander à FixBot
  22. HTC Vive XR Elite Right Speaker Replacement: étape 22, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 22, image 2 de 2
    • Slide the spudger along the gap to separate the plastic clips securing the outer temple.
    Demander à FixBot
  23. HTC Vive XR Elite Right Speaker Replacement: étape 23, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 23, image 2 de 2
    • Pull the outer temple off of its inner half to completely release its plastic clips.
    Demander à FixBot
  24. HTC Vive XR Elite Right Speaker Replacement: étape 24, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 24, image 2 de 2
    Tesa 61395 Tape
    $10.95
    • Let the speaker rest next to the headset before continuing.
    • During reassembly, if your speaker adhesive isn't sticky, use Tesa 61395 Tape to re-adhere the speaker to the outer temple.
    Demander à FixBot
  25. HTC Vive XR Elite Right Speaker Replacement, Peel the hinge tape: étape 25, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Peel the hinge tape: étape 25, image 2 de 2
    Demander à FixBot
  26. HTC Vive XR Elite Right Speaker Replacement, Unfasten the inner hinge cover: étape 26, image 1 de 1
    • One 3.5 mm‑long screw
    Demander à FixBot
  27. HTC Vive XR Elite Right Speaker Replacement, Reposition the inner hinge cover: étape 27, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Reposition the inner hinge cover: étape 27, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Reposition the inner hinge cover: étape 27, image 3 de 3
    • Don't fully remove the inner hinge cover, as it's connected by the volume button cable.
    • Let the cover hang off its volume button cable for now.
    Demander à FixBot
  28. HTC Vive XR Elite Right Speaker Replacement, Unfasten the face plate: étape 28, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Unfasten the face plate: étape 28, image 2 de 2
    • Use a T5 Torx screwdriver to remove the 12 screws securing the face plate:
    • Six 3.5 mm‑long screws
    • Four 4.9 mm‑long screws
    • Two 6.5 mm‑long screws
    • There are two magnets at the top corners of the face plate. As you remove nearby screws, they might stick to them.
    Demander à FixBot
  29. HTC Vive XR Elite Right Speaker Replacement, Unclip the face cover: étape 29, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Unclip the face cover: étape 29, image 2 de 2
    • Insert the flat end of the spudger in the gap between the frame and the bottom right corner of the face cover.
    • Pry up with the spudger to release the clips securing the face cover.
    Demander à FixBot
  30. HTC Vive XR Elite Right Speaker Replacement: étape 30, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement: étape 30, image 2 de 2
    • Repeat the prying process for the middle and bottom left portions of the face cover.
    Demander à FixBot
  31. HTC Vive XR Elite Right Speaker Replacement, Reposition the face cover: étape 31, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Reposition the face cover: étape 31, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Reposition the face cover: étape 31, image 3 de 3
    • Don't fully remove the face cover completely, as it's connected by the proximity sensor cable.
    • Lift the face cover and rotate it over the top of the frame.
    • Lay the face cover face up before continuing.
    Demander à FixBot
  32. HTC Vive XR Elite Right Speaker Replacement, Unfasten the proximity sensor: étape 32, image 1 de 1
    • Use a T5 Torx screwdriver to remove the two 3.3 mm‑long screws securing the proximity sensor cable.
    Demander à FixBot
  33. HTC Vive XR Elite Right Speaker Replacement, Remove the face cover: étape 33, image 1 de 2 HTC Vive XR Elite Right Speaker Replacement, Remove the face cover: étape 33, image 2 de 2
    • Remove the face cover.
    Demander à FixBot
  34. HTC Vive XR Elite Right Speaker Replacement, Disconnect the right speaker: étape 34, image 1 de 3 HTC Vive XR Elite Right Speaker Replacement, Disconnect the right speaker: étape 34, image 2 de 3 HTC Vive XR Elite Right Speaker Replacement, Disconnect the right speaker: étape 34, image 3 de 3
    • Use tweezers to pull the right speaker connector out of its socket.
    • If you're having trouble, try rocking the connector side-to-side to help loosen the connector.
    Demander à FixBot
  35. HTC Vive XR Elite Right Speaker Replacement, Remove the right speaker: étape 35, image 1 de 1
    • Remove the right speaker.
    Demander à FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
Membre depuis le 01/16/22
241 321 Réputation
1 180 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Staff
122 membres
27 504 tutoriels rédigés
0 commentaires de tutoriel
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 45
Total : 656
