Introduction
This guide will show how to remove the old spark plugs, check the new spark plugs for installation, prepare the spark plugs for installation, and reinstall the new spark plugs.
Ce dont vous avez besoin
Carefully remove the spark plug wire. Do not pull on just the wire, squeeze the spark plug boot, and pull it together with the wire.
Always inspect your new spark plugs before installing. Check the gap on your replacement spark plugs with a feeler gauge. It should be set to .040 inches (1.016mm).
Using your fingers, install the new spark plug into the socket, and hand tighten until firm.
Using a torque wrench, tighten the spark plug to the proper specification.
Be sure to repeat the above procedure for the remaining cylinder.
20 autres ont terminé cette réparation.
8 commentaires
Couldn't have made it any simpler
-awesome
- appreciated
Thank you so much for your posting. I'm 2k miles from my daughter who is teaching herself how to maintain her own bike. You site is immensely helpful and appreciated as much.
Says between 11 and 18 pounds in manuel
