Aller au contenu principal
Document vedette
Cette vue éclatée n'est pas un tutoriel de réparation. Pour réparer votre HomePod Mini, utilisez notre manuel de réparation.
  1. HomePod Mini IC Identification, HomePod Mini IC Identification: étape 1, image 1 de 1
    • Side 1 IC Identification, Pt. 1:
    • Apple APL1W82 64-Bit Dual-Core Applications Processor w/ GPU with likely 1 Gb LPDDR3 SDRAM Memory
    • This is the same processor found in the Apple Watch Series 5, just not protected by a boatload of epoxy.
    • Apple 338S00553-A0 Power Management
    • Nordic Semiconductor nRF52833 Bluetooth 5.2 SoC w/ NFC and Zigbee
    • Skyworks SKY66404-11 2.4 GHz Zigbee/Thread/Bluetooth Front-End Module
    • USI 339M00117 WiFi/Bluetooth Module
    • USI UWB Transceiver
  2. HomePod Mini IC Identification: étape 2, image 1 de 1
    • Side 1 IC Identification, Pt. 2:
    • Analog Devices SSM3582A 31.76 W Filterless Stereo Class D Audio Amplifier
    • Texas Instruments CD3217B12 USB Type C Controller
    • Winbond W25Q80DVUXIE 8 Mb Serial NOR Flash Memory
    • Texas Instruments TPS62130B 3 A Step Down Converter
    • Texas Instruments INA199C3DCK Bi-Directional Current Sense Amplifier
    • Dialog Semiconductor SLG46140 Programmable Mixed Signal Array
    • 3 Likely Goertek MEMS Microphones are found around the perimeter of the PCB.
  3. HomePod Mini IC Identification: étape 3, image 1 de 1
    • Side 2 IC Identification:
    • Texas Instruments LP5030RJVR 30-Ch. Constant Current RGB LED Driver
    • Texas Instruments TPS55340RTE 5 A Boost Regulator
    • Austria Microsystems (AMS) Ambient Light Sensor
  4. HomePod Mini IC Identification: étape 4, image 1 de 3 HomePod Mini IC Identification: étape 4, image 2 de 3 HomePod Mini IC Identification: étape 4, image 3 de 3
    • Sensor Flex IC Identifications:
    • Texas Instruments HDC2010YPA Humidity/Temperature Sensor
    • Another likely Goertek MEMS Microphone
CChin
Membre depuis le 06/10/20
7 141 Réputation
7 tutoriels rédigés
3 commentaires de tutoriel
nRF52833 is used for Thread networking protocol. Refer to HomePod mini tech spec: https://www.apple.com/homepod-mini/specs...
Henry Churchill - Réponse
I wonder when are they gonna allow homekit to access the temperature and humidity sensors of the homepod mini?
Jeremy - Réponse
Hello, does anyone have any idea about the specs of the 2R2 inductor near the Texas Instruments TPS62130B 3 A Step Down Converter? Bought a dead HomePod Mini online to try and fix. I noticed that this component was missing on the board. Thank you!
Douglas Gee - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 33
30 derniers jours : 187
Total : 11,530
