Introduction
This guide shows how to remove and replace the brush assembly for the Honda 6500 Watt Generator EG6500CL AT.
Ce dont vous avez besoin
Before you work on the device, make sure to switch the engine off.
Switch the circuit breaker off.
Grab the plastic housing at the end of the spark plug wire.
Pull firmly to disconnect the wire from the spark plug.
Use a Phillips screwdriver to remove the two screws securing the generator cover.
Squeeze and disconnect the stator connector from the wiring harness.
