Aller au contenu principal
Hover-1 Charger Battery Replacement
Ce dont vous avez besoin
  1. Hover-1 Charger Battery Replacement, Battery: étape 1, image 1 de 2 Hover-1 Charger Battery Replacement, Battery: étape 1, image 2 de 2
    • Flip the hoverboard over so that the warning label is facing up.
    • Remove the twelve 12 mm screws with a Phillips #2 screwdriver.
    • Remove the four 10 mm screws with a Phillips #2 screwdriver.
    • The screws nearest to the wheels may be hard to access. Be sure to use a long, thin screwdriver.
  2. Hover-1 Charger Battery Replacement: étape 2, image 1 de 1
    • Pull the right cover away from the hoverboard to expose the battery.
  3. Hover-1 Charger Battery Replacement: étape 3, image 1 de 2 Hover-1 Charger Battery Replacement: étape 3, image 2 de 2
    • Unplug the battery by disconnecting the two pronged black and yellow cable.
  4. Hover-1 Charger Battery Replacement: étape 4, image 1 de 1
    • Pull the left cover away from the hoverboard.
  5. Hover-1 Charger Battery Replacement: étape 5, image 1 de 2 Hover-1 Charger Battery Replacement: étape 5, image 2 de 2
    • Disconnect the two pronged black and yellow cable.
    • Thread the cable through the middle cylinder of the hoverboard.
  6. Hover-1 Charger Battery Replacement: étape 6, image 1 de 2 Hover-1 Charger Battery Replacement: étape 6, image 2 de 2
    • Unscrew the four 10mm screws that are holding the battery casing in place. Use a Phillips #2 screwdriver.
    • If there is a zip-tie connecting the wires together, carefully cut it with a wire cutters.
  7. Hover-1 Charger Battery Replacement: étape 7, image 1 de 3 Hover-1 Charger Battery Replacement: étape 7, image 2 de 3 Hover-1 Charger Battery Replacement: étape 7, image 3 de 3
    • On the battery side, unplug the white five pin connector on the circuitboard.
    • Unplug the black, yellow, green and red connector on the circuitboard.
  8. Hover-1 Charger Battery Replacement: étape 8, image 1 de 1
    • Move all the loose cables to the side. Pull the battery casing away from the battery.
  9. Hover-1 Charger Battery Replacement: étape 9, image 1 de 1
    • Use the opening tool to remove the battery from the metal casing.
    • The battery is stuck to the metal casing with strong adhesive; do not be afraid to apply a strong force with the opening tool.
  10. Hover-1 Charger Battery Replacement: étape 10, image 1 de 1
    • Remove the battery.
3 autres ont terminé cette réparation.
Melanie Hardell
Membre depuis le 10/10/19
505 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team S12-G1, Regan Fall 2019 Membre de l'équipe Cal Poly, Team S12-G1, Regan Fall 2019
CPSU-REGAN-F19S12G1
4 membres
6 tutoriels rédigés
Un commentaire
Can I replace my battery 25.2v to a 36v.
Airie Green - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 49
30 derniers jours : 208
Total : 7,419
